Hello from Alberta!
Stop in and say hi
Hello from Alberta!
Postby off_kilter » Wed Jan 09, 2013 5:54 pm
Hi everyone! I'm originally from Nova Scotia but I'm posted in Edmonton with the Army.
I registered because tomorrow i become the owner of a 1993 extended cab W250 (4WD obviously) with a 5-speed!
Now the truck is pretty tired 500,000 KMs but the frame is straight/solid and the engine pulls strong.
Problems:
-Salvage title :(
-rusty rockers
-middle of the drivers side floor pan is going
-rear cab mounts are in need of replacement
-a couple holes in the rear fenders right above the wheels
-front grill is pretty busted up
-your standard dings and dents
-the shifter is really loose(reminds me of this ancient belarussian tractor i drove once)
the awesome:
cost me very very little money
Looking forward to asking lots of questions and finally haveing my own coal burner (daily driver is a 2010 quad cab 4x4 1400)
off_kilter
Re: Hello from Alberta!
Postby dazedandconfused » Wed Jan 09, 2013 6:46 pm
Welcome to the site.
Postby 12valve » Wed Jan 09, 2013 6:48 pm
Welcome!
12valve
Postby 1STGENFARMBOY » Wed Jan 09, 2013 7:53 pm
first ,welcome
it's too bad you can't get it down to Kentucky, you can have that pesky title problem fixed
for $200 bucks, good as new.
Postby dazedandconfused » Thu Jan 10, 2013 4:24 am
1STGENFARMBOY wrote:first ,welcome
How can he have it fixed in Kentucky?
Postby tampabayBill » Thu Jan 10, 2013 7:19 am
Welcome
Twins coming soon!
tampabayBill
Postby ellis93 » Thu Jan 10, 2013 7:55 am
Welcome
Return to Welcome
