new to cummins, in st. louis MO
Stop in and say hi
Postby PIFFTS » Sat Mar 02, 2013 7:42 pm
Hey guys, name's Jim
Just bought my first diesel last week(1990 cummins ram).
I got a call from my mother, who told me that the lady up the street was selling it. She used it for the occasional pulling of a horse trailer and has 92k original miles. Never been messed with, turned up or anything like that. Only thing I don't like about it is that it's 2wd.
Anyway, plans are to start with a good set of gauges(feel free to recommend a good setup), then I'll turn it up a bit, probably add an intercooler setup, then exhaust, followed by larger turbo, then injectors for when I turn it up a little more.
I'm completely new to this, so I'll take my time, I'm still learning a lot of the acronyms... and have a lot of reading to do.
Anyone in the st. louis area? Any shops anyone would recommend? I'm not even sure if I should keep taking this truck to my old mechanic.
Thanks
PIFFTS
Re: new to cummins, in st. louis MO
Postby PIFFTS » Sat Mar 02, 2013 7:47 pm
PIFFTS
Postby cmann250 » Sat Mar 02, 2013 7:50 pm
Welcome aboard! Nice barn find, I wish mine looked like that! In my opinion, if you consider yourself even vaugely mechanically inclined, you can make these trucks run two times better than stock. These old Cummins engines are argueably the simplest engines ever put in a pick-up truck.
Postby PIFFTS » Sat Mar 02, 2013 7:59 pm
Agreed, I think the only thing keeping me back as far as working on it is just being nervous about messing something up(simple or not). I've never had a diesel and I'm not going to kid myself into thinking working on it will be just like my f150. Just want to do things right the first time. Thanks for the welcome.
PIFFTS
Postby ellis93 » Sat Mar 02, 2013 8:11 pm
Welcome! Nice truck! :thumright:
Postby oldestof11 » Sun Mar 03, 2013 6:19 am
I will trade you my 4x4 5spd for that in a heartbeat...
Welcome! I live about 5 hours north of you.
Postby CumminsPower59 » Mon Mar 04, 2013 7:18 am
Welcome! That thing is beautiful! Good score :thumright:
Postby braptor52 » Mon Mar 04, 2013 11:27 am
welcome, im new as well. i have been doing a decent amount of research on a nice clean setup an i have decided to use isspro 2 1/16" boost, pyro an a tach. (r5613r, r3607tr, r5501) place two gauges on an a pillar duel pod mount an one on a steering column single pod mount.
braptor52
Postby tampabayBill » Mon Mar 04, 2013 12:39 pm
Welcome, Nice find Be sure to thank your Mom !
Twins coming soon!
tampabayBill
Postby dazedandconfused » Mon Mar 04, 2013 3:01 pm
Welcome nice truck.
Postby hager » Wed May 01, 2013 8:57 pm
nice rig !! I live north of you in Bowling Green Missouri
hager
Postby hager » Wed May 01, 2013 9:01 pm
hager
Postby rockbuggy4x4 » Sun May 05, 2013 1:04 pm
sweet rig. and welcome.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Return to Welcome
