newbie from carolina
Stop in and say hi
Postby toolkeys » Fri May 10, 2013 5:53 pm
Hello all, from eastern North Carolina here. Have a 1st gen and looking to learn more about it!
Not sure if photo links will work!? First try!?
http://i1312.photobucket.com/albums/t54 ... 3bb997.jpg
toolkeys
Re: newbie from carolina
Postby cmann250 » Fri May 10, 2013 6:01 pm
Photobucket is acting weird as of recently. You just need the IMG code.
Anyways, welcome! Is it stock?
Postby RCCUMMINS89 » Fri May 10, 2013 6:28 pm
welcome............. and DARN NICE TRUCK
Postby dazedandconfused » Fri May 10, 2013 6:46 pm
Welcome
Postby toolkeys » Sat May 11, 2013 6:36 am
Thanks guys! Its a 93, got it about a year back bone stock with 98k miles. Installed lift kit and wheels and messing with the power now but taking my time!? Of course gauges went in first! But completed so far; intake, 4" turbo back, Denny t pin, bigger gov spring, timing bump and pump turned up.
Need/want; kdp fix, injectors, turbo upgrade, lift pump(maybe a p-pump upgrade too!?), intercooler and piping, trans work!? And etc.... oh and paint but that's not high on my priority list :roll:
toolkeys
Postby BC847 » Sat May 11, 2013 8:33 am
Where about in eastern NC are you?
Postby toolkeys » Sat May 11, 2013 9:08 am
David, I'm In Bath 27808, oldest incorporated town in the state! bout 45min east of Greenville (ECU). you in eastern NC too?
Mike
toolkeys
Postby oldestof11 » Sat May 11, 2013 9:45 am
Welcome!
Iirc, BC847 is his call sign. Bc standing for Buise Creek?
Postby BC847 » Sat May 11, 2013 9:47 am
oldestof11 wrote:Welcome!
Correct. Buies Creek. :)
Postby toolkeys » Sat May 11, 2013 10:00 am
Cool, I'll have to look that up...not ringing a bell yet!?
toolkeys
Postby BC847 » Sat May 11, 2013 10:05 am
Eight or so miles from Benson (I95 & I40).
Postby toolkeys » Sat May 11, 2013 10:32 am
Ok, I know where that is! Any 1st gen or Cummins "get-togethers" around the piedmont that you know of?
toolkeys
Postby CumminsPower59 » Sun May 12, 2013 6:34 am
Welcome!
Very nice truck!
Postby tampabayBill » Mon May 13, 2013 6:20 am
Welcome !!! Nice truck.
Twins coming soon!
tampabayBill
Postby rockbuggy4x4 » Sat May 18, 2013 3:55 pm
Sweet ride! Welcome.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Return to Welcome
