Howdy from NC- 93 w350
Stop in and say hi
Postby Q5Quint » Tue Jul 09, 2013 8:19 am
Hello everybody.
I picked up a 93 dually with about 130k on the clock a few months ago and have been slowly sifting through all the issues. You folks seem like you have a lot of answers so I figured I would join up.
She has low miles but is a rusty girl. I didn't notice how bad the frame was when I picked it up. Already ripped the rear spring hanger in half towing a 16ft trailer and a little vw bug.
Issues so far:
New spring hanger and shackle, finished yesterday. Rides way better (I think the old one was binding).
Door pins loose/gone
Squeaky tensioner- needs new belt
Radio doesn't work
Tail light wiring is odd/broken-no running lights, reverse lights on when running lights are on. I re-wired the headlight switch and used a relay, the PO had done some of this already, and the running lights worked for about 2 hours before burning something out.
Smoke stack is wayyy too loud right behind my head- have a new 4" kit to put it back to the rear.
Frame welding is questionable- you can see where the truck was severely overloaded and broke above the axle in the rear as well as where the rear of the front springs connect to the frame. It is 'fixed' but it does not look safe or pretty.
Transmission doesn't like to shift properly unless the tcase is in 4hi for some reason.
Pump pin supposedly turned up by PO- judging by the amount of black smoke this is true.
already has boost and egt gauge, 4wd works great.
Plans:
Beef up auto transmission as this is my tow rig.
Full fluid change on everything. Had a jeep j10 a year ago that made odd sounds until they got louder and louder- turns out the rear diff was full of mud so I want to prevent that this time around.
Small/free hp mods for engine, but reliability and longevity are more important.
4 link or traction bar the rear as I don't fully trust the rusty spring hangers and rusty frame mounts to fully hold the axle in place.
Paint is ok but needs touching up in places.
Need new tires soon.
Needs front visor put back on, you can see the holes where it was removed.
Needs new drop hitch bolted/welded on- truck is so damn tall all my trailers are too low for it. Has the 16k lb pintle hitch there but it is non adjustable/non tube style so I cant run a drop hitch.
Let me know your thoughts on general tow-rig improvements- hope to meet some of you all one day soon.
-Quint - Boone NC
Q5Quint
Re: Howdy from NC- 93 w350
Postby CumminsPower59 » Tue Jul 09, 2013 8:24 am
Welcome! Looks like you got a good plan :thumright:
Postby ellis93 » Tue Jul 09, 2013 8:30 am
Welcome!
Postby Mark Nixon » Tue Jul 09, 2013 9:42 am
Welcome!
One thing you'll need to do is, quite simply, READ.
Next is figure out the Search Function on here, as a lot of the questions you'll have are pretty well beaten to death. :D
BTW, LOVE your ride, red/white in a Dually E/C is definitely one of my favorite color schemes.
Postby rockbuggy4x4 » Tue Jul 09, 2013 12:02 pm
Welcome.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby cmann250 » Tue Jul 09, 2013 12:23 pm
Welcome! It snows in North Carolina?!?!?!?!
Postby Q5Quint » Wed Jul 10, 2013 10:32 am
In the mountains of NC we are in the same climate zone as Chicago. Less snow though because we don't have the lakes. They get 50-60 inches a year, we get about 35. It snowed for 22 days straight back in 2010 I believe it was. The rest of NC gets about .5 inches a year maybe.
Here was one from 2010-
I also found a pic of that little volkswagon rabbit diesel with the variable vane setup~
Got a new tension-er and belt on the dodge last night, fixed the squawkin. Tonight if the rain holds out we stick on the 4" exhaust kit and get rid of the giant smokestack that is in the way of my toolbox. I did a really good inspection of the front end and it looks like I need all new ball joints and everything up there. I may make a post asking about that coming up soon too. Also looks like the right real drum cylinder is leaking a bit of brake fluid, and on inspection of the master cylinder it looks like somebody went crazy bending in some new brake lines. Always something! Thanks everyone!
Q5Quint
Postby RCCUMMINS89 » Wed Jul 10, 2013 12:08 pm
8)
welcome
Postby theoldmanW350 » Wed Jul 10, 2013 12:09 pm
Good lookin rig! Welcome.
theoldmanW350
Postby directinjktn1stgen » Mon Jul 15, 2013 6:53 pm
From one North Carolina 1st gen owner to another welcome! You will learn alot from this site i know i have.
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby 1grumpy » Tue Jul 16, 2013 12:48 am
welcome 1st 3 things I'd get on that truck is pyro/boost/trans temp gauges nice truck I have the 2wd version
1grumpy
Return to Welcome
