new member
Stop in and say hi
new member
Postby depogrig » Tue Aug 13, 2013 7:18 am
Wanted to pop in and say hello. Bought a 90 w250 to shorten the frame and swap a jeep Cherokee chief body onto. This site has a lot of great info so thanks.
Greg
depogrig
Re: new member
Postby RCCUMMINS89 » Tue Aug 13, 2013 7:41 am
Pics - will be interesting.
Re: new member
Postby ellis93 » Tue Aug 13, 2013 8:10 am
Welcome! AND :worthless: WAITING :popcorn:
Re: new member
Postby depogrig » Tue Aug 13, 2013 9:09 am
I'll post the few pics I have when I get home for you guys
depogrig
Re: new member
Postby depogrig » Tue Aug 13, 2013 2:08 pm
here is the jeep as it sits right now. I just started tearing it down last weekend.
here is the donor ram while, needed to replace fuel lines. with a topped off tank the easiest was was to unbolt the bed and tip it over the side. tailgate wont fit back on now but oh well
and here is the truck helping me split the cut on a tree we took down beginning of the summer
depogrig
Re: new member
Postby rockbuggy4x4 » Wed Aug 14, 2013 2:15 pm
welcome.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Re: new member
Postby dazedandconfused » Wed Aug 14, 2013 2:48 pm
Welcome
Re: new member
Postby depogrig » Sun Feb 23, 2014 9:26 am
After driving the truck through the winter and evaluating my needs I've decided the Cummins doesn't fit what I'm looking for. About a month ago on my way to work in the morning the engine shut off on me. Not sure if it gelled or iced or the fss croaked. I've swapped the filter with a new full one and primed with the banjo loose but Havnt loosened the injectors. It cranks quickly but just won't start. I'm going to try to sell it locally and go with a gen iii/iv SBC swap. Thanks for helping when I needed it. Hopefully I can get it running and not take such a huge loss on the truck
depogrig
Re: new member
Postby dazedandconfused » Sun Feb 23, 2014 10:22 am
Where are you located at in Indiana? Might have someone close that can give you a hand or be interested in the truck as it sits.
Re: new member
Postby depogrig » Sun Feb 23, 2014 10:49 am
NW Indiana. About 30 miles SE of Michigan City
depogrig
Re: new member
Postby cmann250 » Sun Feb 23, 2014 11:12 am
No chit? I'm in Lafayette.
Crack the injectors and see if fuel squirts out of them. If they have fuel to them, run 12v to the FSS and see if it clicks. Otherwise it more or less has to be the fuel supply.
Re: new member
Postby depogrig » Sun Feb 23, 2014 11:16 am
I've got 2 foot drifts between the house and the barn. Where my wrenches are. I can hear the fss click when I remove the wire amd touch it again. Hopefully it will warm up and I can get out and mess with it some.
depogrig
Return to Welcome
