Hi from Oz
Stop in and say hi
Hi from Oz
Postby oka374 » Thu Dec 05, 2013 4:57 pm
Just bought a 6BT to fit to my 4wd motorhome here in Oz.
Used Cummins engines are pretty expensive here too, parts are also hard to come by.
My engine was a genset engine and it is a Cummins full rebuild in 2009, has the later style block etc but full mechanical injection so it is a bit of a mystery as to what bits fit when converting it to vehicle use.
Currently chasing a few small parts to enable me to fit it in the vehicle, most from older 1st gen engines.
oka374
Re: Hi from Oz
Postby Tacoclaw » Thu Dec 05, 2013 5:11 pm
Crikey!!
I hope Oz is Australia. :lol:
Welcome to the site, man.
Re: Hi from Oz
Postby RCCUMMINS89 » Thu Dec 05, 2013 7:11 pm
welcome
Re: Hi from Oz
Postby ellis93 » Fri Dec 06, 2013 4:13 am
Welcome
Re: Hi from Oz
Postby ihredneck » Fri Dec 06, 2013 6:56 am
Good luck with the build
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Re: Hi from Oz
Postby CumminsPower59 » Sat Dec 07, 2013 10:04 am
Welcome! We like pictures here, so post some up when you get going on your build!
Re: Hi from Oz
Postby dazedandconfused » Sat Dec 07, 2013 12:45 pm
Welcome
Re: Hi from Oz
Postby cubedeficient64 » Thu Jan 02, 2014 1:50 pm
Hello Oka, where are you located? Im in Central QLD, doing a similar swap 6bt pump engine into an inter truck.
It was new in 1997 but has ve fuel pump. Good luck on your build.
cubedeficient64
Return to Welcome
