New join in the Denver area.
Stop in and say hi
Postby Landmissile » Sat Jan 10, 2015 6:53 pm
Quick hello. Just joined the forum. Living in the Denver area. I have a 1990 Cummins W250 I've done a bunch of work to with plenty to go. Joined to lurk for info and see what other folks have done with their 1st Gens.
Couple shots for proof of life...
1990 Cummins W250 Foolsize
Landmissile
Re: New join in the Denver area.
Postby oldestof11 » Sat Jan 10, 2015 8:06 pm
Welcome!
Plans to install 4 link and coilovers on the front?
Postby CumminsPower59 » Sat Jan 10, 2015 8:18 pm
Welcome!
Pretty slick ride! 8)
Postby Landmissile » Sat Jan 10, 2015 9:06 pm
oldestof11 wrote:Welcome!
Thank you. I've been on the fence with linking the front. I have everything to do it except the coilovers. At the moment I'm planning to graft the OEM rear primary leafs to the lifted front pack that's currently under it. The rears are 4 in longer then the front. I'll need a slightly longer set of shackles and probably pull a leaf or two from the bottom. Should make the front much more flexible. I like how it drives right now but the front is a little to rigid for really serious off road. Or what I want to do at least.
I want an OX Locker for the front pretty bad. Likely put my money there for the next move.
Landmissile
Postby Landmissile » Sat Jan 10, 2015 10:16 pm
CumminsPower59 wrote:Welcome!
Appreciate that.
Landmissile
Postby RCCUMMINS89 » Sun Jan 11, 2015 12:41 pm
Wow, great looking truck.
Postby ellis93 » Sun Jan 11, 2015 2:12 pm
Welcome.
Postby Landmissile » Sun Jan 11, 2015 2:28 pm
RCCUMMINS89 wrote:Wow, great looking truck.
ellis93 wrote:Welcome.
Thank you. I really like how it turned out. I had a vision when I started wrenching on it. I had to rush the tube bed a little due to work but it really came together. It definitely draws some looks on the road. LOL
Landmissile
Postby PToombs » Sun Jan 11, 2015 5:12 pm
What's that on the front fender, battery shut off?
Postby Landmissile » Sun Jan 11, 2015 5:47 pm
PToombs wrote:What's that on the front fender, battery shut off?
No it's a military slave receptacle. My jumper cables have the plug on one end. My winch is on a cradle mount, also with the same plug for "plug and play" operation. Works great but I obviously need to finish the front bumper so I have something to attach it to. I'm re-bracketing the front bumper right now to lift it a bit.
There's another slave receptacle tucked inside the rear bumper so the winch can be run off the rear. Still need to finish building and plumbing the cable to the batteries for that one though.
Landmissile
Postby PToombs » Mon Jan 12, 2015 6:30 pm
Ah, gotcha! Cool idea!
Return to Welcome
