Been reading for a while, finally joined
Stop in and say hi
Postby spencerdiesel » Tue Oct 27, 2015 4:17 pm
Hey guys, I've been reading all the great info from this forum for a couple years, and I finally joined. I'm stoked! One thing I've always wondered but never found a concrete answer for is sustained EGTs with timing advance.
Because the burn starts sooner (and stays in the cyl longer), would the max sustainable egt of 1250 be unsafe? Because the cyl temp has actually increased? I know there's tons of guys (probably most) who advance timing and have zero issues, but is there a scientific answer?
Thanks.
H1C/18
Muffler delete
spencerdiesel
Re: Been reading for a while, finally joined
Postby Richie O » Wed Oct 28, 2015 4:29 am
My thought is advanced timing makes the piston hotter. Thats my opinion, I have 1 truck advanced, and my other 2 at factory spec.
Postby PToombs » Wed Oct 28, 2015 4:43 pm
IMO, cylinder temps shouldn't increase a lot, because the coolant is collecting the heat and dissipating it. Plus, the piston coolers are still squirting oil up under to cool the pistons. And the max of 1200* is exhaust temp, which will actually go down a little with the timing increase.
Unless the timing is way increased, then I can see you having problems keeping the cylinders cool.
Re:
Postby spencerdiesel » Wed Oct 28, 2015 5:22 pm
Thanks guys. Would someone benefit from timing advance (hp gain) with lil bitty IC injectors? I know the more fuel, the more time is needed for it to burn, and it will be a while before I can get 5x12s. Should I wait till I've got the firehoses before I advance time?
H1C/18
Muffler delete
spencerdiesel
Postby RCCUMMINS89 » Sat Nov 07, 2015 8:49 pm
Welcome. Advancing the timing a little on stock injectors is still beneficial.
Postby spencerdiesel » Sun Nov 08, 2015 8:23 am
Thank ya. I think I read a thread one time talking about running the spacer and X psi of boost before HG failure. Can't find the thread could you inform me how much psi is safe w/ spacer only?
H1C/18
Muffler delete
spencerdiesel
Return to Welcome
