Log In
Moderators: Greenleaf, BC847
Log In
Postby Mike T. » Sat Dec 15, 2007 7:48 am
I have to go through the log in procedure twice before I can actually log in. Can this be corrected?
Thanks
Mike
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby CAJUN 93 » Sat Dec 15, 2007 8:03 am
yep, whats bad about that is after the 2nd time you hit the :new post since last visit" thing and it tells you nothing exist. thats a real pita.
daryl
CAJUN 93
Return to 1st Gen.org suggestions
