changing aviar's size
Moderators: Greenleaf, BC847
Postby cummins king » Wed Feb 20, 2008 7:33 am
the current aviar max size is only 6kb, can we make it bigger to 10kb, that way we can ad moving ones
thanks
93 4X4 auto
cummins king
Postby swank » Wed Feb 20, 2008 8:44 am
how bout now?
truck
swank
Postby cummins king » Wed Feb 20, 2008 3:21 pm
perfect
thanks
93 4X4 auto
cummins king
Postby ford69557ci » Wed Feb 20, 2008 4:57 pm
thanks swank i have been wantin video avatars for quite a while.
ford69557ci
Postby flashgordon » Wed Feb 20, 2008 7:22 pm
ford69557ci wrote:thanks swank i have been wantin video avatars for quite a while.
Ford Your demented...........it is kinda funny tho :P
Flash
flashgordon
Postby PToombs » Thu Feb 21, 2008 6:01 pm
Shoot, I don't have a clue how to do that! :oops:
Postby CAJUN 93 » Fri Feb 22, 2008 7:26 am
no pete, you cant change your avatar. unless of course you have a moving sheep........ :shock:
daryl
CAJUN 93
Postby cummins king » Fri Feb 22, 2008 8:07 am
93 4X4 auto
cummins king
Postby PToombs » Fri Feb 22, 2008 6:24 pm
I'm sure I could find a moving sheep video, but I'd probably get banned from the site! :safe: :oops:
What I meant was I don't know how to do a video avatar.
Postby TWorline » Fri Feb 22, 2008 8:55 pm
You, a sheep and a video? :shock:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby dpuckett » Fri Feb 22, 2008 10:48 pm
When CAJUN mentioned the moving sheep, I immediately thought of Pete chasing right behind it. Probably right, he'd get banned from the site, for sure.
But then, he could come back as Scotty Pete.:mrgreen:
Daniel
Postby cummins king » Sat Feb 23, 2008 10:49 am
u guys :shock:
with my moving aviar it, i right clicked on the mouse went save as saved it like a regular pic, then if its the right size you just go on first gen and load it like a regular aviar, but rember you cant resize it, so it must fit in the requarments
80x80 size
and max 10kb
93 4X4 auto
cummins king
Postby PToombs » Sat Feb 23, 2008 1:25 pm
You guys! :oops: I don't actually have a sheep video. Unless the farmer got me on tape that nite..... Anyways, I think I'm getting a bad rep here! :shock:
Joel, thanks for the tips. ;)
Postby cummins king » Sat Feb 23, 2008 2:51 pm
no problem
93 4X4 auto
cummins king
Postby flashgordon » Sat Feb 23, 2008 10:24 pm
Flash
So what happen to you avatar?????
flash
flashgordon
Return to 1st Gen.org suggestions
