crossover steering: pitman arm issue
Postby josh_6bt » Wed Oct 17, 2012 8:25 am
Hey guys, I just put crossover steering on my 92 W250 and I love it, but the pitman arm my using (jeep wj arm) brings the draglink real close to engine crossmember, especially if I turn to the right. I heard of guys using the skyjacker DA20 arm and I was wondering if it has more drop than the jeep arm. Anyone got a measuremnt of the skyjacker DA20 arm?
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Re: crossover steering: pitman arm issue
Postby BILTIT » Wed Oct 17, 2012 10:24 am
Can you get a pic of how close it is? I have no real issues with mine.
Derek B.
BILTIT
Postby josh_6bt » Wed Oct 17, 2012 1:52 pm
Ill try get one after work. Hoepfully I can figure out how to post pics thru my Blackberry lol. I have an s-bend draglink from northwest fab. Its got the right bend just if it was lower on the steering box end it would make my issue disappear. When its fully turned to the right I have roughly 1/2" of clearence IIRC.
josh_6bt
Postby oldestof11 » Wed Oct 17, 2012 3:23 pm
Do some searching. There is a guy who tried northwest fabs kit and ended up doing his own stuff.
Postby BILTIT » Wed Oct 17, 2012 3:34 pm
I tried NWFab and did my own lol. Only because i have 2'' lift, 4" or more and their kit should be fine.
Its long but a ton of info of my crossover attempt with NWFab:
http://www.dieseltruckresource.com/dev/ ... 91427.html
Derek B.
BILTIT
Postby josh_6bt » Wed Oct 17, 2012 6:54 pm
Ok so I'm don't have my laptop with me as I'm working outta town and cant post pics without it. So does any have a measurement of the skyjacker arm P/N DA20? I just wanna compare notes before I buy. Thanks.
josh_6bt
