"soft" brakes after rebuild
Postby Jelmer » Tue Jan 05, 2016 1:33 am
I've rebuild the front and rear brakes of our 93 D250 and the pedal felt good/hard like it should be. Now after a couple of month's the pedal started to feel soft all of a sudden. I've checked for leaks but I can't find anything.
What I've done so far:
* Reseal calipers
* New pads
* discs/rotors milled/resurfaced(don't know how you call that in english)
* New 3" shoes
* New Chevy wheel cilinders (the bigger ones)
* New hardware all around
The brakes felt good and it braked like it did a couple of years ago (These trucks brake like sthi I ghuess...)
Master cilinder? It looks like it is the one it came with from the factory! Are there any improved ones?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: "soft" brakes after rebuild
Postby ellis93 » Tue Jan 05, 2016 4:54 am
I'd check the adjustment of the rear brakes first.
Postby PToombs » Tue Jan 05, 2016 5:54 pm
^ what Ellis said, check the adjustment, then the next thing I would do is delete the ABS valve if it is still on there. If it's gone then I'd do the master cylinder. It could be the master, as old as the truck is, but that darn ABS valve is a more common problem.
Postby ihredneck » Mon Jan 11, 2016 7:23 am
^ Dido, I did have my master give out and was soft on me. It didn't show signs of leaking either, it was internal. If you do the master, be sure to bench bleed as well.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
