hrydo boost
hrydo boost
Postby scottdevall@yahoo.com » Wed Jun 08, 2011 3:36 pm
has anybody put the 94 and newer hydro boost on the first gen truck cause im thinking of doing it to my truck. and or has anybody put the abs system for a 94 and newer into the first gen
Re: hrydo boost
Postby firstgenjunkie » Wed Jun 08, 2011 4:11 pm
http://www.dieseltruckresource.com/dev/ ... ost2582890 is the link to a guy over on DTR who did a VFAQ for the conversion.
Rich
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Re: hrydo boost
Postby Gots_a_sol » Wed Jun 08, 2011 4:35 pm
I used mid 90's chevy parts for mine, the bolt holes lined right up, I just had to flip the factory chevy bracket upside down and oval out the center hole a bit. In fact, I even used the factory chevy lines, just had to bend them a bit.
Like this, but it needs to go down vs up (which is how it lines up when the bracket is flipped)
I tee'd the return line into the factory line from the box to the pump, but I don't really care for that arrangement. I want to pick up a second gen pump with the 2 return barbs one of these days.
-Joe
Gots_a_sol
Re: hrydo boost
Postby scottdevall@yahoo.com » Wed Jun 08, 2011 10:02 pm
what chevy vehicle did you get that off a 1 ton pick up and did it help
Re: hrydo boost
Postby Gots_a_sol » Thu Jun 09, 2011 12:25 pm
it was a mixed collection of whatever trucks had the better looking pieces. mostly 2500/3500's though. I'm pretty sure the booster/master came out of a diesel truck.
-Joe
Gots_a_sol
Re: hrydo boost
Postby scottdevall@yahoo.com » Thu Jun 09, 2011 4:37 pm
so 73 to 91 would work right for chevy or would it have to be a newer
Re: hrydo boost
Postby Gots_a_sol » Thu Jun 09, 2011 5:12 pm
all the trucks I robbed the parts from were around 95 model years with the 6.5td
The rod on the chevy booster was too long and the end was different. I just cut it off and welded the dodge end on at the correct length.
-Joe
Gots_a_sol
Re: hrydo boost
Postby scottdevall@yahoo.com » Sat Jun 18, 2011 10:12 pm
would a 70's and early 80's chevy hydoi boost work cause my uncle has one that is on a parts truck that has a hydro boost with a 6.2 diesel and it doesnt look like the newer 6.5 diesel one's
Re: hrydo boost
Postby scottdevall@yahoo.com » Thu Sep 08, 2011 3:11 pm
so i found a hyrdo boost at the junkyard and paid 40 bucks for it, and i also had lee steering rebuild my whole steering system and the run special fluid. and i called them to rebuild the hrydo boost for around a 100 bucks. so a cheap upgrade
Re: hrydo boost
Postby 1990 » Thu Sep 08, 2011 6:12 pm
I've got a old hydroboost from a late 70's chevy. Let us know if it bolts up.
2012 Subaru WRX TP Stage 1 DD
Re: hrydo boost
Postby scottdevall@yahoo.com » Thu Sep 08, 2011 8:00 pm
did you notice a big improvment when you put it on
Re: hrydo boost
Postby manyholes » Sat Sep 10, 2011 4:38 am
i got mine out of a mid 2000 gm, mounting flange is different, had to drill the firewall and bend some lines but defiantly like the hydro-boost
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: hrydo boost
Postby BobS » Sat Sep 10, 2011 11:28 am
I have NOT tested the following but I believe it is a lot easier provided it should be a direct bolt on to the firewall and brake pedal. I posted this originally over on 4BT Swaps:
Posting this info for you guys who may want to use factory supplied replacement parts to add hydroboost brakes to your 70's - 90's half ton Dodges, Ramchargers, & Traildusters. This is available from your local auto parts store that sells Cardone steering and brake booster parts. The current average price is in the low $200 range or less (June 2009). This may or may not fit earlier Dodge vehicles when converting from front drum brakes to disk brakes when used in conjunction with the newer master cylinder. Please report your findings and results in this thread.
The factory source is the 1978 thru 1980 Dodge D100 trucks that were available with the 6D05 Mitsubishi engine.
It is listed in the catalog as:
1979 DODGE D100 PICKUP 4.0L 243cid L6 DIESEL FI (H) : Brake/Wheel Hub : Power Brake Booster;
A-1 CARDONE Part # 529385
{[Hydro-Boost] Remanufactured} w/Hydro-Boost;
Possible Applications:
DODGE B200 VAN (1979 - 1980)
DODGE B200 VAN MAXI (1979 - 1980)
DODGE B200 VAN MAXI WAGON (1979 - 1980)
DODGE B200 VAN SPORTSMAN (1979 - 1980)
DODGE B250 VAN (1981 - 1984)
DODGE B250 VAN SPORTSMAN (1981 - 1984)
DODGE B300 VAN (1979 - 1980)
DODGE B300 VAN MAXI (1979 - 1980)
DODGE B300 VAN MAXI WAGON (1979 - 1980)
DODGE B300 VAN SPORTSMAN (1979 - 1980)
DODGE B350 VAN (1981 - 1984)
DODGE B350 VAN SPORTSMAN (1981 - 1984)
DODGE CB300 (1979 - 1980)
DODGE D100 PICKUP (1978 - 1979)
DODGE D150 PICKUP (1978 - 1980)
DODGE D200 PICKUP (1978 - 1980)
DODGE W150 PICKUP (1978 - 1980)
DODGE W200 PICKUP (1978 - 1980)
Disclaimer: This information is provided for use at your own risk!
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: hrydo boost
Postby firstgenjunkie » Sun Sep 11, 2011 12:13 pm
Bob,
Great ref. I didn't even know they had on hydroboost on the mitsu diesel.
firstgenjunkie
