Hey guys this summer I had the outer pad on my RF wheel start grinding. All the other pads were still like like 8mm. I was pressed for cash so I took it apart and even though the rotor was trashed, I just threw pads in to get me by. I noticed that the RF caliper did not want to slide and had become rusted pretty tight between the bracket.
When I took it all apart I cleaned out all the sliding surfaces and sanded off any rust that was there. Even cleaned up the little "leaf springs" that I found in there for tension on the calipers. Then I applied copper brake lube / anti sieze from 3M and put it all back together.
Now the problem is that whenever I drive down any road with even the smallest bumps, it makes the most god-aweful rattling and clunking like the front end is gonna fall out. But if you lightly ride the brake pedal, it is quiet as can be over even the biggest bumps.
I noticed when I had the wheels off more lately that if you wiggle they pads they are very loose in the calipers, and also the calipers themselves now kinda slide around and have some play between the bracket.
What can i do to fix this?
1993 W250 auto
