Bleeder broke on my abs pump...
Postby Diesel » Thu Nov 10, 2011 7:45 pm
The bleeder on the abs pump is snapped off but I didn't do it. I don't want to eliminate the pump but I do want to bleed it now that I have new wheel cylinders on the rear. Does anyone know what size thread it is? Same as wheel cylinders?
1991.5 D250 Intercooled A518
Diesel
Re: Bleeder broke on my abs pump...
Postby skilletky » Thu Nov 10, 2011 10:02 pm
Dont know the thread size, but youll be happier bypassing the abs valve
skilletky
Postby Diesel » Fri Nov 11, 2011 9:19 am
It would probably be cheaper to bypass...
Diesel
Postby diesel freak01 » Fri Nov 11, 2011 10:50 am
I also agree bypass is the only way to go. My rear brakes never worked until i bypassed the ABS and then the truck would actually stop like it should. I even have the bypass fittings at the house because when i went to bypass i ended up having to replace all of my rear brake lines.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Diesel » Thu Dec 08, 2011 8:17 pm
So the broken bleeder must be allowing air into my brakes incredibly slowly. I put new rear cylinders on and bled it out a couple weeks ago. My pedal no longer would hang up. Now its back to hanging up unless I pull it up. Pretty sure if I bleed it the pedal will be fine. The ABS pump isn't leaking but the bleeder is broken in it. Any tips? Could the pump be the cause of my hanging pedal? Thing is when I bleed it the problem is gone I think...but the pump also isn't leaking so how could it be letting air in?
Can anyone link to the parts list to bypass the valve?
Diesel
Postby Diesel » Thu Dec 08, 2011 8:54 pm
This is what I found to bypass WEA 7917 & WEA 7828
Just those two from NAPA and the rest is bolt together?
Diesel
Postby diesel freak01 » Fri Dec 09, 2011 6:08 am
Yes, you disconnect the rubber line from the ABS and these two fittings connect the rubber hose to the brake line direct. I suggest a couple days of some PB blaster before you plan to do it as mine broke and I ended up replacing all the brake lines. Bad day.
diesel freak01
Postby Diesel » Fri Dec 09, 2011 9:45 am
I am hesitant to replace the unit with another one. For $100 I can get a Raybestos remanufactured unit but I am worried that I will spend $100 on the unit and just have it cause my rear brakes to stick again on unless i pull up on the pedal. Any success stories on the remanufactured parts?
Diesel
Postby dazedandconfused » Fri Dec 09, 2011 1:55 pm
Just eliminate it and be done with it.
Postby Diesel » Fri Dec 09, 2011 6:41 pm
I hate that I am removing the ABS pump but I guess anything is better than having a pedal I have to manually pull back. I'll probably try and run a flare on the rear line and bend a hardline to the rear rubber line. Could anyone tell me the size of the stock metal line so I can go buy a section of it? Thanks.
Diesel
Postby ellis93 » Fri Dec 09, 2011 6:54 pm
Should be 3/16ths
Postby Diesel » Fri Dec 09, 2011 8:27 pm
Appreciate it. So hopefully I can flair a section of stock line and use a 3/16" line to mate to the rubber hose at the axle. So do these dodges use bubble flairs?
Diesel
Postby ellis93 » Fri Dec 09, 2011 8:45 pm
Nope, regular old flare or double flare
Postby PToombs » Sat Dec 10, 2011 5:57 pm
Just use the adapters listed a few posts back and the 2 sections of steel line will bolt together. Or, if you are replacing the line from the front, just go direct to the hose, that's a regular end the brake line nut will screw into.
The ABS valve just has different fittings in it, that's why some guys use the adapters.
Postby Diesel » Thu Dec 15, 2011 6:47 pm
Confused: so I bought those two fittings which each have a male and female side. There are two lines going into the abs pump. Do I take the lines out, bend them a little so they bolt together? What coupler do I use?
Diesel
