How to change ride height?
Postby cummins12club » Tue Dec 18, 2012 8:59 pm
I've got a 4wd ext cab truck that has the leveling kit on the front from what I've been told it sits nice and level but I want to lower it about 2 inches Mabey 3 max and was curious as to how I can do that?
cummins12club
Re: How to change ride height?
Postby bmoeller » Wed Dec 19, 2012 1:06 am
Remove the leveling kit. :P
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby cummins12club » Wed Dec 19, 2012 3:54 am
Where the heck am I Gunna find the stock springs? And how do I go about lowering the rear end?
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 5:17 am
Post a few pictures up of your front springs. You stated it had a leveling "kit", so it may have an extra spring or two under the front that you could remove...
Postby cummins12club » Wed Dec 19, 2012 7:19 am
I do t have a photo bucket account so I can't post pics I wonder if u can still buy the springs new from Chrysler
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 8:13 am
Not sure if you can or not, but at SOP, fourspeedsteve had new OEM front springs on his 91.5 he restored...
Postby cummins12club » Wed Dec 19, 2012 1:04 pm
Hmm ill have to do some research I was thinking putting stock non listen leaf springs on the front and then getting shorter blocks for the rear to match the height drop in the front how much drop will I get out of stock style springs?
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 1:17 pm
An inch or two. You can't go too low or you'll really limit your suspension travel. Why do you want to lower it back down?
Postby cummins12club » Wed Dec 19, 2012 1:26 pm
For looks mostly and it would have to handle better ive got a friend w a 4wd reg cab and he has stock springs in front hand his truck handles much better then mine
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 1:45 pm
Handling? Does yours have "looser" steering or something like that? There are many factors that can contribute to "loose" handling, king pins, tie rod ends, drag link, steering gear box, steering shaft, etc. I would check those things over before changing springs. That's alot of work for something that might not net the desired result you want ;)
Postby cummins12club » Wed Dec 19, 2012 2:00 pm
My steering is old and loose I have a Borgeson steering shaft that was a night and day fix I want to get a Borgeson steering box I believe they make a quick ratio one and all new front end stuff I want to lower mainly for a look I'm going for
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 2:16 pm
I see...since you got a worn gear box, just putting on a reman will help out a bit.
As for lowering, probably just remove the leveling kit, the springs will sag back to stock and it will get lower how you want... it can only go down a few inches then the springs will be up against the bump stops...
Postby cummins12club » Wed Dec 19, 2012 2:35 pm
My springs are arched up and my buddy's truck has the prongs arched down in the front it looks like that's how they raise the front in theirs no block on my front like used in the rear I don't want it to go down anymore then about 2 inches just to stock height and lower the rear to match
cummins12club
Postby CumminsPower59 » Wed Dec 19, 2012 2:50 pm
If they have a positive arch, then they are probably actual lift springs. The stock springs are darn near flat, maybe just a slight positive arch to them, and then turn to a negative arch over time, like on your buddy's truck. Since you have a club cab, then you probably have the factory 6" blocks in the back. Find some out of an 89-91, as they had 3-4" blocks in the back and swap them in. Get a photobucket account and let's see them springs you got, someone on here might want to buy them from you, then it would keep the cost of lowering your truck to stock down some ;)
