2nd gen dually adapters
Postby DodgeFreak » Wed Sep 02, 2015 7:26 pm
Hey I seen someplace someone used 2nd gen dually adapters on a 1st gen 4x4. Does anyone know any more details on how to make them work?
Re: 2nd gen dually adapters
Postby Philip » Wed Sep 02, 2015 7:59 pm
You need to have 9/16's studs a little longer than the stocks studs. One of our lug nuts on the adapter only has two threads into the nut. Plus the adapter can move with the 1/2 studs you have.
NAPA does have a 9/16's stud with the same sized knurled section. I don't have the number for it.
Postby DodgeFreak » Wed Sep 02, 2015 8:31 pm
Thanks! I figured I needed 9/16th studs since that's what the 2nd gens ran. And thanks for the heads up on the longer studs. Will any 2nd gen adapter work?? Also did anything need machined?
Postby CumminsPower59 » Thu Sep 03, 2015 10:03 am
Dorman 610-283 has the same knurl diameter, but since I did the conversion, there are even longer studs now, about 3" long. The ones I used are about 2 1/2" long. I don't have the part number for the longer studs, but I'll do some digging quick...
Postby CumminsPower59 » Thu Sep 03, 2015 10:05 am
Dorman PN 610-563. 3" long.
Postby DodgeFreak » Thu Sep 03, 2015 2:41 pm
Thanks Ike!
Postby oldestof11 » Thu Sep 03, 2015 6:16 pm
I just saw on the Book of Faces yesterday that Chevy adapters fit perfectly.
Postby matthewh » Fri Sep 04, 2015 1:43 pm
I noticed that as well, but wasn't sure if they just "slid" over the hub and bolted into place?
matthewh
Postby DodgeFreak » Sat Sep 05, 2015 12:18 pm
From what I've seen 2nd gens slide into place. What year chevys work?
Users browsing this forum: No registered users and 57 guests
