After a 1 year break to build a shop, I'm back. The puller has moved into an area where there is enough room around it to work and soon the dually will be indoors as well.
I was sorting through some parts today to post up on the local cl and started eyeballing some 98-02 2nd gen engine mounts vs. the craptastic stock first gen mounts on a spare 92 engine I have. It looks possible, just curious if someone might have done it already? My first gen mounts are plated solid, have reinforcing plates under the crossmember, and an overload chain is starting to distort the crossmember slightly. It's loud and vibrates horrendous, I might put it back on the street and step down to pull in the "modified" classes at fairs since PPL 2.6 just went stupid.
