Hydro boost brake conversion?
Postby jeff77indy » Fri Jun 18, 2010 3:57 am
Those of you that have completed this conversion, was it worth doing? Would you do the change again? Anything you would have done different?
I am kicking the idea of doing it on my '92 since I'm going to need to completely rebuild the brake system anyway.
There was a post on another forum where he used a Chevy unit spaced out to accommodate the longer push rod that seemed pretty straight forward in the change over.
Thanks
Jeff
U.S. Navy Submarine Service Retired
1992 W350 C&C w/ 9' flatbed, NV5600, Skyjacker 2" lift, Borgeson , Isspro, draw straw, big line kit, piston lp, swiss cheesed air housing.
jeff77indy
Re: Hydro boost brake conversion?
Postby KTA » Tue Jun 22, 2010 11:27 am
I would absolutely do it again. I run 23000lbs gross and its the only way I can get the truck to stop as fast as it accelerates!
Postby mhuppertz » Sat Jul 31, 2010 2:52 pm
KTA wrote:I would absolutely do it again. I run 23000lbs gross and its the only way I can get the truck to stop as fast as it accelerates!
What unit did you use KTA?
mhuppertz
Postby KTA » Fri Aug 06, 2010 6:01 pm
I used everything off a 85 GMC K30 from wheel cylinders( Dana 70 as well in dually trucks) to master and booster.
