wheels are lined up
wheels are lined up
Postby 93 dually » Sun Jun 24, 2007 12:35 am
Well 70 mph my steering wheel looks like a basketball the truck is hammering so bad it feels like its going to rip the frontend off .
Ive got new tires wheels balanced .Or am i blaming it on the wheels and its somthing else ive been trying to find this prob for three long years ive got a great truck that runs like a dream but cant get out of town anyhelp or ideas would be cool im lost :x :x :x ive replaced hubs drums studs bearings all the way around carrier bearing ujoints whats left :x like i said before it did it with the eagel alloys and it has brand new stock steel wheels on it now
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby jogl » Sun Jun 24, 2007 4:37 am
Have you done the front brakes, rotors, calipers, pads, etc?
Ball joints, tie rods, whatever other parts there are in the two wheel drive steering?
Is your steering box loose?
Keep looking, good luck, let us know what you find.
JP.
92 W250 and lots of others.
jogl
Postby PToombs » Sun Jun 24, 2007 4:40 pm
Ball joints, A-arm bushings, strut bushings, shocks? I'd look at all these also. Especially the strut bushings and the A-arm bushings.
Postby KTA » Sun Jun 24, 2007 10:06 pm
I once had a brand new general tire cause your symptom, a new replacment cured it, the tire looked fine and balanced good with only 2oz of weight, but something was wrong inside of it and it had a bad spot that caused the vibration.
Postby 93 dually » Mon Jun 25, 2007 11:08 pm
Thanks everyone for the info ill let you know what i find
93 dually
thanks to everyone
Postby 93 dually » Fri Jul 06, 2007 1:10 am
Well dont ever take your truck to bigo for wheels or tires ive got 5 bent wheels :evil: and one tire out of round i spent over 2000 on new wheels and tires to have all these problems they are trying to get me new wheels now after a fight asked them why didnt your tech see it before and there comment was they always come in bent :x :x :x :x people need to have pride in there job no matter what it is im a 30 year mech on harleys been born and raised mech people need to take pride and this crap would not happen
93 dually
Postby KTA » Fri Jul 06, 2007 5:46 am
The reality is that the dually wheels are very prone to getting bent and they usually are bent to some degree. If they are not out more than .250" then they should be OK. The biggest problem usually with these trucks is the wheel installer not using the pilot nuts to line up the wheel. The retards at Chrysler thought stud piloted was better than hub piloted and therfore installing the wheels correctlty is a pain in the ass. If they are not installed with the pilot nuts then you usually will have a vibration from the wheels acting like they are out of round.
Postby BEARKILLER » Sat Jul 07, 2007 5:35 am
Factory ton wheels are usually good enough to run.
Any aftermarket wheel, little bitty car or big old truck, will most likely have considerable run-out, right out of the box.
We completely quit dealing in aftermarket wheels for that very reason.
Aluminum are much worse than steel.
As to the incompetency of some installers, I had a lady bring in her like-new 97 Dodge/Cummins with a tire going flat.
She could not put air in it.
When I looked at it, some moron had mis-matched the air-valve access holes, and then put the stainless simulators on mis-matched to the wheels.
The holes in the simulators were over solid steel, and the holes of the outside wheels were offset from the insides.
Even the front simulators were wrong.
You would think he would have accidentally gotten at least one lined up right.
To add to the situation, they had installed pop-in rubber passenger-car-type valve-stems, and one of these failing was the cause of her flat tire.
#4 = 1991 D-350 LE Getrag
BEARKILLER
