Tire Size Question
Re: Tire Size Question
Postby slow_90firebird » Sat Sep 03, 2011 6:53 pm
Wow i cant believe you guys like the caps and rings better... i just think they make the truck look too 1970's
slow_90firebird
Postby dazedandconfused » Sat Sep 03, 2011 7:04 pm
I think it makes it look trashy personally without them but that's me.
Postby bmoeller » Sat Sep 03, 2011 7:56 pm
Yep. Put 'em back on. 8)
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Hansen01 » Sat Sep 03, 2011 11:25 pm
i agree :alien:
Under construction...
Hansen01
Postby manyholes » Sun Sep 04, 2011 7:33 pm
run 'em bare, i like that look myself and if ya hit some trails or play in the bush, you dont have to worry bout loosing anything off the rim but the rear dog dish cap does make a good parts bin when in the bush
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Postby CumminsPower59 » Wed Sep 14, 2011 6:23 pm
It depends on the truck. Yours, for instance, I would keep them on. I am running the stock steelies too, but mine have been painted black, to match the rest of the blacked out theme on my truck...so it looks ok. I am running 285/75R16 Dick Cepeck FCII's, they rub a bit on the Pittman arm, but every truck I have ever had has had the largest tires I could fit on, so it doesn't bother me. :grin:
Postby 93DodgeCummins » Wed Sep 21, 2011 7:44 pm
Iv been thinking about getting some rims off a 06 dodge diesel and was planning to put on 265/75/R17 tires? Would i have any problems with clearance? The thing im mostly worried about is will they drop my mileage much?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Postby lopez dodge » Thu Sep 22, 2011 2:36 pm
i dont see why it would affect mileage . the stock size 235/85/16 measure out 31.7x9.25
the 265/70/17 measure 31.6x10.4 .
I have ran from the stock 235's to 255/85/16 and now 315/70/17 never noticed the milage change until the 315's( dropped it a little) but my last tank avergaged out to 18.7 and I don't exactly baby my truck
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Postby oldestof11 » Thu Sep 22, 2011 3:11 pm
My 33x12.5's on a 16.5" rims when aired up to 60psi all around, netted me 23 on the highway and and 19.4 220 mile highway and 230 miles town.
Postby 93DodgeCummins » Thu Sep 22, 2011 9:27 pm
my speedometer is 3mph too fast so im trying to find a tire for a 17inch rim that will have a slightly bigger diameter than stock 16 inch rim so i can even up my speedometer.
93DodgeCummins
Postby lopez dodge » Wed Sep 28, 2011 9:30 am
The tires that marked the most accurate on mine was the 255/85/16. I think they make a255/80/17.
I just put a set of 265/70/17 that I got for free and my speedo marks too fast with these.
lopez dodge
