Steering dampers
Re: Steering dampers
Postby Mark Nixon » Wed Mar 14, 2012 7:38 am
Hansen01 wrote:if my injection pump ever gets back from the pump shop id let you guys know if there worth it, but at this rate its never coming back :roll:
Andrew or I could have fixed the problem in very short order and been way more friendly about it.
Who will you use next? :lol:
Postby Hansen01 » Sun Mar 18, 2012 6:44 pm
You mark, your next on my list of people to call, lol my turbo leaking more and more oil into my intercooler and need to get a deal worked out with ya :lol:
PS: drove the truck today and steering dampners definately helped with the drivability, bandaid or not i like them :D
Under construction...
Hansen01
Postby REBELHIGHBOY » Tue Mar 20, 2012 5:50 am
My old f150 on unbalnced 33 swampers had no stabilizer and all i did was run the high way with it, No shakes or shimmy like a few people have said its more of a bandaid for a real problem
REBELHIGHBOY
Postby scottdevall@yahoo.com » Sun Mar 25, 2012 2:52 pm
so i now that a steering damper is a band aid for problems.
but when a person like me that has all new steering part minus the column. And now wanting to just have the tightest steering possible would the damper tighten it up a little more.
and after reading one of the post about stress on the steering parts, so in esence wouldnt having a steering damper make the steering last longer because the damper takeing the abuse
Postby Hansen01 » Sun Mar 25, 2012 8:00 pm
scottdevall@yahoo.com wrote:so i now that a steering damper is a band aid for problems.
in theory if you put them on it should take some of the jolt out of your wheel, and make your steering box last a little longer
Hansen01
Postby chicknnhead » Fri Apr 06, 2012 6:16 pm
thanks for listing the part numbers, it makes my search a little easier. mine has the orginal on it
chicknnhead
Postby Fred_M1010 » Tue Apr 10, 2012 1:42 am
Hansen01 wrote:in theory if you put them on it should take some of the jolt out of your wheel, and make your steering box last a little longer
Not just in theory.
As I said earlier, that is what they are designed to do.
-91.5 W250
Fred_M1010
