Replaced Rotors and Pads. Now hanging up?
Re: Replaced Rotors and Pads. Now hanging up?
Postby ellis93 » Tue Jan 22, 2013 5:48 pm
You got it figured out :thumleft:
Postby 93DodgeCummins » Tue Jan 22, 2013 6:24 pm
How does your guys brakes disengage? Can you spin the wheels and will they keep spinning or do they stop fairly quickly?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Postby PToombs » Tue Jan 22, 2013 6:27 pm
They stop kinda quick. The caliper always drags a little, but the rotor should be free to turn.
Postby 93DodgeCummins » Tue Jan 22, 2013 6:41 pm
i put 20 pounds of weight on one the studs and the rotor did not spin so im guessing it takes 25-30 pounds of weight to over come the drag of the pads on the rotor. idk if this helps explain how tight it is or not. I really dont want to buy calipers if i dont have have to
93DodgeCummins
Postby ellis93 » Wed Jan 23, 2013 4:00 am
93DodgeCummins wrote:i put 20 pounds of weight on one the studs and the rotor did not spin so im guessing it takes 25-30 pounds of weight to over come the drag of the pads on the rotor. idk if this helps explain how tight it is or not. I really dont want to buy calipers if i dont have have to
You should be able to put one finger on the sidewalll of your tire and spin it,if not the calipers are screwed.
Postby PToombs » Wed Jan 23, 2013 5:53 pm
You should be able to put 2 fingers on the rotor and turn it. You may not want to, but the calipers are junk, so buy new ones! ;)
Postby 93DodgeCummins » Wed Jan 23, 2013 7:13 pm
Well i drove it some today and then jacked up to check again. seemed to be much better so im gonna stick with the ones i got for now. After i opened the bleeder the brakes feel better too. I guess maybe the pads needed some more breaking in. Thanks a lot guys! Im not trying to be a PTA. Money is tight right now so the less that needs fixin the better
93DodgeCummins
