Late Model OEM 8 Lug Wheels That Work/Fit 1st.GEN.Trucks?
Re: Late Model OEM 8 Lug Wheels That Work/Fit 1st.GEN.Trucks?
Postby DodgeFreak » Tue Apr 22, 2014 10:15 am
If you wanted to go to a 16.5 there are wide 16.5s out there.
Postby RumbleFish » Tue Apr 22, 2014 12:21 pm
Ive always heard good things about stockton.
Im not following what youre saying. My steel wheels came off a 2wd van, and they fit my w250 fine with the same lugs. 2 and 4wd trucks both have 1/2-20 studs, u less its a 350 with the 5/8 studs but that would also mean you have dual wheels.When I was looking for steels I found a set off a early 90s f250 that were 16x7 and looks like the factory caps would fit.
Postby Fred Average » Tue Apr 29, 2014 7:39 am
What I need is lug nuts that fit the OEM 4WD steel rims that have a larger seat base where the nut tightens up against the rim ...and also are the correct size of the 2WD wheel/hub studs which are smaller in diameter that the 4WD application.
What did you use/buy/find that works?
Thanks :lol:
Fred Average
