caliper brackets?
Re: caliper brackets?
Postby TRENDZ » Wed Nov 17, 2010 5:58 pm
I've repaired this same thing with stainless filler rod/ tig welder. The brackets are cast steel, not cast iron, so repair is very simple.
TRENDZ
Postby Richie O » Wed Nov 17, 2010 6:02 pm
TRENDZ wrote:I've repaired this same thing with stainless filler rod/ tig welder. The brackets are cast steel, not cast iron, so repair is very simple.
Yup, cast steel is easy. I have used stick, and mig with that.
Postby ahale2772 » Fri Dec 03, 2010 7:13 am
wow, cast steel does make it easier thats a big developement....my right side is doing it now, guess ill get the mig out, seems like that bracket is gona take up alot of heat though
Postby PToombs » Fri Dec 03, 2010 6:34 pm
Glad this thread came back up, saved me from looking for it. I did brakes on the wifes car and the outer pad has worn a deep hole in the bracket. Now I know what to weld it with. 8)
Postby ahale2772 » Fri Dec 03, 2010 8:37 pm
all im woried about is that the bracket is going to suck all the heat out of the weld
