by Remps » Wed Apr 20, 2011 8:32 am
An update on these springs: If you are replacing your 2wd front springs and want a factory-like ride, do not buy the 5716's. Unless you want to feel every single bump..I'm still happy with them, and the truck handles the big bumps nicely, instead of wallowing around. The 90 feels like a cadillac in comparison tho. With 245/75 on the front I'm at 34-1/2" to the outer wheelwell, 34" on the rear sitting on 235/85's. So when I put 235/85 on the front it will probably be another inch higher on the front..Has anyone ever used coil over shocks on the back of there truck? Did it lift the back end a little?
