Leaf Springs?
Leaf Springs?
Postby collegekid » Mon May 30, 2011 8:34 pm
What size leaf springs do you guys suggest to optimize ride quality, but also give me a little bit of a lift, tire size btwn 33-"35". Im getting into my 2wd to 4wd conv, and am going to replace the OEM front leaves with something different, just need some advice from those who know or have done before
collegekid
Re: Leaf Springs?
Postby 1stgenblowingsmoke » Tue Jun 07, 2011 11:12 pm
Skyjacker soft ride leafs.
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Sat Jun 25, 2011 9:52 pm
deaver is the only company to use americans steel and they custom make the springs for your personally. i just got some made for me a little bit expensive but they really stand behind there springs. if you want pictures or questions let me now
Re: Leaf Springs?
Postby BILTIT » Sat Jun 25, 2011 9:57 pm
Alcan is also a good company for custom soft ride springs.
Derek B.
BILTIT
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Sat Jun 25, 2011 10:09 pm
BILTIT wrote:Alcan is also a good company for custom soft ride springs.
the deavers are soft rides to but they say i can carry the same amount of weight and than some cause they put overloads on mine
Re: Leaf Springs?
Postby ivel_86 » Wed Jun 29, 2011 6:35 am
9MM wrote:Skyjacker soft ride leafs.
I can agree with you that for the price these do ride nice....BUT they sag horribly. They sag from the engine weight in the front and when pulling or loaded with anything they sag in the back. I would not recommend these to anyone.
US ARMY SGT
OIF 08-09
'93 W250, 4in Sky Lacker 35in Kelly Safari, Pump turned up, Fuel Pin ground, Pyro and Boost gauges, Straight piped, Home made air cleaner assembly.
ivel_86
Re: Leaf Springs?
Postby collegekid » Wed Jun 29, 2011 7:34 am
Im thinking about just leaving the stock springs and doing a 5" drop shackle
collegekid
Re: Leaf Springs?
Postby tampabayBill » Wed Jun 29, 2011 4:20 pm
Don't do shackles or blocks save your bucks for springs - do it one time and do it right.
Twins coming soon!
tampabayBill
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Wed Jun 29, 2011 4:24 pm
when i had deaver make my spring i spent al little extra money for them to make the lift with all spring and no blocks or shackles
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Thu Sep 08, 2011 3:05 pm
so i started on the deaver lift kit today so i should have the lift kit done this weekend and the bilstien shocks in to, so shoot me question if you have any and i will post pictures to
Re: Leaf Springs?
Postby lucky91 » Wed Sep 14, 2011 5:33 pm
scott,
Any updates on the install?
lucky91
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Wed Sep 14, 2011 11:24 pm
ya i have some good news and bad news. i have the front installed and done. but a little problem my uncle has have me working all week welding so hopefully i will have a chance on monday to start working on it, and i have to move the hangers back 2 inches so im hoping by next week i have it done. sorry about the delays but when you are getting paid $40 bucks and hour to weld and i need the money so please be pantiet with me. and i took care of me leaking grease seal problem, its fuuny cause it was the metal tube that screws in to the axle for the vent tube so i wont have oil soaked braskes any more hopefully.
Re: Leaf Springs?
Postby scottdevall@yahoo.com » Sat Oct 01, 2011 7:50 pm
so hopefully i will have it done tomorrow night or monday so be ready for one hell of a write up. i just have had made sthi loads of fabircation and me and jeff the designer at deaver have made a lot of changes and fixes to get the springs perfect so get ready for my views on them
