I have NOT tested the following but I believe it is a lot easier provided it should be a direct bolt on to the firewall and brake pedal. I posted this originally over on 4BT Swaps:
Posting this info for you guys who may want to use factory supplied replacement parts to add hydroboost brakes to your 70's - 90's half ton Dodges, Ramchargers, & Traildusters. This is available from your local auto parts store that sells Cardone steering and brake booster parts. The current average price is in the low $200 range or less (June 2009). This
may or may not fit earlier Dodge vehicles when converting from front drum brakes to disk brakes when used in conjunction with the newer master cylinder. Please report your findings and results in this thread.
The factory source is the 1978 thru 1980 Dodge D100 trucks that were available with the 6D05 Mitsubishi engine.
It is listed in the catalog as:
1979 DODGE D100 PICKUP 4.0L 243cid L6 DIESEL FI (H) : Brake/Wheel Hub : Power Brake Booster;
A-1 CARDONE Part # 529385
{[Hydro-Boost] Remanufactured} w/Hydro-Boost;
Possible Applications:
DODGE B200 VAN (1979 - 1980)
DODGE B200 VAN MAXI (1979 - 1980)
DODGE B200 VAN MAXI WAGON (1979 - 1980)
DODGE B200 VAN SPORTSMAN (1979 - 1980)
DODGE B250 VAN (1981 - 1984)
DODGE B250 VAN SPORTSMAN (1981 - 1984)
DODGE B300 VAN (1979 - 1980)
DODGE B300 VAN MAXI (1979 - 1980)
DODGE B300 VAN MAXI WAGON (1979 - 1980)
DODGE B300 VAN SPORTSMAN (1979 - 1980)
DODGE B350 VAN (1981 - 1984)
DODGE B350 VAN SPORTSMAN (1981 - 1984)
DODGE CB300 (1979 - 1980)
DODGE D100 PICKUP (1978 - 1979)
DODGE D150 PICKUP (1978 - 1980)
DODGE D200 PICKUP (1978 - 1980)
DODGE W150 PICKUP (1978 - 1980)
DODGE W200 PICKUP (1978 - 1980)
Disclaimer: This information is provided for use at your own risk!
