front springs and hangers
Postby gobigorgohome » Thu Jun 23, 2011 4:41 pm
im gonna be doing an axle swap this summer an i know i will need new front springs (doing rears also) and the hangers for thee front. at one point in this trks life i got wrecked or somethin and the sprint hangers got welded back on and it pulls goin down the raod an the alightnemt is on on it an i just wannt get rid of the welded parts does abnyone know of a reasonable place to get all these prts for my trk?
front springs pins and bushings if they dont come with em
front spring hangers
rear springs with pins and bushings
u bolts i can get from work for cheap
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Re: front springs and hangers
Postby collegekid » Thu Jun 23, 2011 4:45 pm
Jungle over on ramchargercentral makes direct bolt on kits, I am going to be ordering a set to go from 2wd to 4wd, and he has EVERYTHING I need, front and rear hangers, steering re-enforcement kit for crossover steering etc
collegekid
Postby gobigorgohome » Fri Jun 24, 2011 4:06 pm
couldt find much of anyhting there. maybe i wasnt lookin in the right spot
gobigorgohome
Postby collegekid » Fri Jun 24, 2011 4:11 pm
gobigorgohome wrote:couldt find much of anyhting there. maybe i wasnt lookin in the right spot
http://ramchargercentral.com/jungleshddodgecomponents/
Try that link, that is to his vendor section
collegekid
Postby kwrank » Fri Jun 24, 2011 7:09 pm
i went with benz spring in portland, or. they can build anything you want. excellent quality and service.
92 W250 CC HX35/16 366 190's lp piston lift hughes converter
kwrank
