by firstgenjunkie » Sat Aug 06, 2011 2:25 pm
slow_90 firebird,
IIRC our rims are lug-centric whereas the H2 ones are hub-centric. I think the regular truck studs were 1/2" and duallys were 5/8". If you're going with the jeep studs I'd make sure they're at least 5/8", get all conical nuts & work a star pattern and you should be good. Or you could just go for 9/16" studs and given in to overkill.
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
