what axle
what axle
Postby spencermumma » Mon Aug 08, 2011 8:49 pm
looking to run 4.10s and a locker or a spool but wondering which axles i have for front and rear both have a 1990 dodge with th e slipomatic wondering what i can do since i think i have a dana 71 since i have 3.o7s anything i can do?
thanks spencer
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
Re: what axle
Postby Mark Nixon » Tue Aug 09, 2011 10:14 pm
The 3.07 housing is unique for those gears.
From what I know, you'd be experimenting by putting 4.10s into the rear housing.
The front axle is a Dana 61 and I believe they were available with deeper gears, since some earlier Ford 4WD trucks came with Dana 61 rear axles and had different gear ratios.
Re: what axle
Postby spencermumma » Wed Aug 10, 2011 10:21 am
so basically it would be easier to just get a dana 70 correct?
spencer
spencermumma
Re: what axle
Postby Mark Nixon » Wed Aug 10, 2011 12:47 pm
Or 80. :D
Re: what axle
Postby spencermumma » Wed Aug 10, 2011 1:43 pm
So what years will fit?
spencermumma
Re: what axle
Postby Mark Nixon » Wed Aug 10, 2011 3:54 pm
'94 up on the Dana 80 will "work".
It's a bit more of a hassle to install and it is somewhat wider overall than the axle you have under it now.
Any Dana 70 from 1989 through 1993 is a direct bolt in, so long as you stick with the single wheel, like you already have.
Re: what axle
Postby spencermumma » Wed Aug 10, 2011 4:09 pm
You wouldn't know or have anything in the years range would ya?
Spencer
spencermumma
Re: what axle
Postby Mark Nixon » Wed Aug 10, 2011 4:38 pm
I don't have any personally, but I can check with 1 fellow I know and see if he still has the 3.55 one he had a week ago.
Re: what axle
Postby spencermumma » Wed Aug 10, 2011 9:11 pm
any way i could run a 3.55 gear in my axle or am i stuck with the 3.07s?
spencer
spencermumma
Re: what axle
Postby spencermumma » Mon Aug 15, 2011 8:52 pm
Bump
spencermumma
Re: what axle
Postby Philip » Fri Aug 19, 2011 5:14 pm
spencermumma wrote:any way i could run a 3.55 gear in my axle or am i stuck with the 3.07s?
spencer
I only know of one person that has installed another ratio in a 71 axle. He spent time on a lathe getting a carrier modded to work.
3:54 axles are easy to find. Post a wanted to trade add. There are always people looking for the 3:07's.
