Any writeup's on front rotor replacement on 2wd D250 trucks?
Postby Diesel » Thu Sep 01, 2011 11:22 am
My front rotors are warped from when the calipers locked up :( - any writeup's on how to replace them and what else to replace when in there? I would guess just get the rotors and new bearings? I've never replaced 2wd front rotors so a more detailed explanation would be really nice :)
1991.5 D250 Intercooled A518
Diesel
Re: Any writeup's on front rotor replacement on 2wd D250 trucks?
Postby ellis93 » Thu Sep 01, 2011 11:35 am
I assume that you know about the bearings so I'll skip that, to take the rotors off the hub you knock out the studs then the assembly will split apart. To knock out the studs I usually screw a lug nut down on the stud to keep from damaging the threads.
To reassemble you drive the studs back in with a drift pin and a hammer. Its a fairly simple job ;-)
Postby Diesel » Thu Sep 01, 2011 11:39 am
Ellis - sorry I don't know anything about the bearings. What do I do with them? I am guessing I have to replace them with some new timkens. What torque to put on the hub nut? Any other key torque values? I am trying to knock this out on Monday.
Diesel
Postby Diesel » Thu Sep 01, 2011 11:49 am
Also - if the vehicle has good alignment and doesn't have any wheel bearing issues then I can just buy the rotor without the hub right?
Diesel
Postby ellis93 » Thu Sep 01, 2011 12:03 pm
I don't have any torque specs per say :bom: but there will be two bearings in there along with two races inside the hub. They and the hub/rotor assembly are held together by a castle nut and cotter pin.
To remove: extract cotter pin and unscrew castle nut. Next there should be a washer and the outer bearing, pull them out and re install the castle nut, after nut is back on grab the rotor at the 3 and 9 o'clock positions, allow the rotor to rest on the spindle, now pull the rotor toward you forcefully. This will allow the nut to catch the inner bearing and seal and remove them.
As far as reassembly, pay attention to that castle nut. You don't want to tighten it up hard, you'll burn up your bearings. to get it right I spin the rotor while I tighten the nut, just as soon as I feel spinning resistance I stop and back off about a 1/16 of a turn or till I can install a cotter pin back in. One other thing buy new cotter pins.
If the bearings aren't burnt or pitted you don't have to buy more.
Postby Diesel » Thu Sep 01, 2011 12:12 pm
Ok thanks! So I will just get rotors and reuse my hubs. Should I be replacing that seal or is that replaceable.
Diesel
Postby ellis93 » Thu Sep 01, 2011 12:17 pm
I typically reuse them unless they are torn or the rubber is really hard
Postby Tacoclaw » Fri Sep 02, 2011 4:34 pm
Writeup on replacing/servicing your D250 brakes
The rest of the DTR "Sticky"
1stgen.org's very own Sticky
If it involves basic maintenence, the Sticky there or here should be your first destination. If it's not in there, then it probably needs it's own specific thread.
Postby Diesel » Sat Sep 03, 2011 7:17 pm
Thanks guys. Any idea what the hub nut size is?
Diesel
Postby ellis93 » Sat Sep 03, 2011 8:42 pm
Channel lock pliers ;) Its not tight
Postby Diesel » Sun Sep 04, 2011 10:25 am
ellis93 wrote:Channel lock pliers ;) Its not tight
Thats my favorite size :)
I got the rotors with hubs cheaper than just rotors but now I am just hoping its the right part. The new hubs have races but not the bearing...can I install old bearings with new races or should I just tap in the old races with the old bearings?
Diesel
Postby ellis93 » Sun Sep 04, 2011 10:40 am
I've never bought a two piece assembly already put together. Its always just the rotor. There's two different axles for these trucks. Ones 4000# diesel and one for gas 3600#, not sure about the gas poundage. The gas rotors are one piece.
You can use the new races with the old bearings, as long as the bearings are in good shape.
