Diesel wrote:Looks like you have the single bag not the shackle dual bags? The single bag is just a massive center bag to hold more weight, right? I am looking for the cushy ride 2 bags
Diesel wrote:Not quite. The single bag will hold more weight and help ride if you remove a leaf. The dual bag just hangs the shackles from airbags. The purpose is to rely on the airbags until you load it up enough to need the spring rate from the leafs. You gain zero load capacity but gain mucho ride quality.
bmoeller wrote:This is the early single bag setup like I have-
http://www.dieseltruckresource.com/dev/ ... 1191299294
Diesel wrote:So 1 bag looks like it will also isolate the springs from the chassis with the bag? Does installation require any permanent changes to the frame?
Richie O wrote:That one bag could pick up the entire truck's weight twice over. I bet the springs would break off before the bag got maxed out.
