Ok one of the projects I wanted to tackle before winter was taking the bed off and finding a new way to secure it down to the frame. And also make some spacers to adjust the way it sits on the frame.
After reading the other thread on here called "flexed out bed" i realized that i am not alone in having all kinds of factory shims and the bed is still not straight. I would rather use blocks with holes than body shims though because shims fall out eventually.
Last year I tried to loosen the bed bolts near the rear and three broke clean off in the bed. So I am driving around with 5 now.
I wouldnt mind taking out the bed liner and running big 1/2" bolts and washers from the top down... but how would I know where to drill the holes?
I cant be the only one who has had these dinky little stock bolts break off, what have you guys done?
