No heat to floor
No heat to floor
Postby Diesel » Sat Oct 01, 2011 7:54 pm
When on heat no air blows out the floor vents. What's wrong?
1991.5 D250 Intercooled A518
Diesel
Re: No heat to floor
Postby TWorline » Sat Oct 01, 2011 9:12 pm
A couple of things comes to mind:
The actuator rod has come unhooked from the door.
You have a vacuum leak to the actuator.
The control unit went bad.
You have a nest or other debris in the heater box which is stopping the door from moving.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Diesel » Sun Oct 02, 2011 2:15 pm
Nest is really possible. In terms of vacuum - what line do I check or replace?
Diesel
Postby TWorline » Wed Oct 05, 2011 6:11 pm
Un latch your glove box so you can see the heater box, with the truck running switch it from defrost to heat and watch the diaphragm on the left side for movement. Here is an article on removing the heater box: http://www.dieseltruckresource.com/dev/remove-hvac-box-t248580.html?t=248580
Tim Worline
TWorline
Postby quickie70 » Tue Oct 11, 2011 5:00 pm
I was also wondering about this... except mine is in the defrost. Mine was a farm truck and sat in the field for the last 8 years, and has all sorts of weird junk that come out of the vents when the fan is running. I'd be willing to bet I've got a bunch of that junk in there, as well as some issues with the vacuum. Which line should there be vacuum on when it's running?
1991.5 RCLB 4x4 LE Rag w/ 3.54's 200,000+ miles, original denny T, WH1C, P/S I/C with coolertubz, pump turned up slightly, DDP stage 1's, gauges (lots of em). Custom Anti-Rusting-undercarriage 15/40 coating provided by leaky timing cover. 306 HP / 599 TQ.
quickie70
Postby bmoeller » Wed Oct 12, 2011 8:34 pm
Too bad I didn't see this earlier. I got vacuum hooked up to my HVAC controls tonight. Only had the truck for about 17mths. :roll: Opened the glove box to see the actuators and such on mine. They're all working now. :) Still can't turn the heat off, without closing off the ball valves I installed. Cable is attached on both ends, and the door moves. Probably just not moving the blend door far enough.
They lines are color coded. With the truck running, you can pull hoes off by hand to see which one is supposed to do what, if it has vacuum.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
