Suspension
Suspension
Postby rrfarm » Sun Oct 09, 2011 12:17 pm
Just removed the front axle from my truck. Anybody know about the bracket that's mounted to the frame that hold the rear shackle. I removed the rubber insert and it has 2 bushings pressed in from both sides do they need to come out if you're replacing the bushings or do the new rubber bushings go inside the steel bushings?
92 Dodge W350, Diesel, 5spd, 4x4
Crew Cab conversion and motor upgrade project.
rrfarm
Re: Suspension
Postby 1990 » Sun Oct 09, 2011 4:24 pm
Yes the outer shell will come with the new bushings.
http://www.summitracing.com/parts/ENS-5-2102G/
If you get this. You need to take out the outer metal shell.
I just put the summit kit in.
2012 Subaru WRX TP Stage 1 DD
Re: Suspension
Postby rrfarm » Sun Oct 09, 2011 4:29 pm
1990 wrote:Yes the outer shell will come with the new bushings.
Checked that out looks good but it didn't show the metal bushings just the rubber ones but you say they do come with it.
rrfarm
Re: Suspension
Postby 1990 » Mon Oct 10, 2011 2:11 pm
No.. The summit kit doesn't come with the outer metal pieces. You don't need it with the summit kit. The poly bushings press in, with out any outer metal shell.
The only place that you can get stock style bushings is from a dealer, i think.
Either option you will have to remove the outer metal shell.
Re: Suspension
Postby rrfarm » Mon Oct 10, 2011 2:13 pm
Excellent thanks
rrfarm
