Driveshaft length and yoke size
Postby 1990 » Thu Oct 27, 2011 5:06 am
Anybody know if the rear drive shafts are the same on 3 speed auto and Getrag trucks?
What is the size of the yokes on the NP205 and D70? D70 is a 1990 and NP205 is a 29 spline from 1993.
4x4 Reg. cab long box.
I looking to get one made up.
Thanks
2012 Subaru WRX TP Stage 1 DD
Re: Driveshaft length and yoke size
Postby Philip » Thu Oct 27, 2011 6:05 am
Yes the getrag and 727 use the same drive shafts.
Postby ahale2772 » Thu Oct 27, 2011 6:34 am
agreed the shafts are the same length.
yoke size of the d70 is a 29 spline 1410, rear yoke on the np205 is a 1410 32 spline
Postby 1990 » Thu Oct 27, 2011 6:35 am
Thanks guys
Postby ahale2772 » Thu Oct 27, 2011 6:42 am
No problem. d60/d70 share the same yoke splines (with same seal), as do the front/rear outputs on the np205(but different seals).
what are you getting made for a drive shaft? thicker tube? regular 1piece drive shaft tubes are super thin, expecially if they have any rust
Postby 1990 » Thu Oct 27, 2011 7:31 am
I need to get a rear drive shaft made up for my 4wd conversion. I measured one from a 4x4 727 truck just too get the length.
I going to call a drive-line shop tonight and see what they can do. I want a one piece shaft with the slip joint, like the stock ones.
Postby 1990 » Thu Nov 03, 2011 4:19 pm
ahale2772 wrote:No problem. d60/d70 share the same yoke splines (with same seal), as do the front/rear outputs on the np205(but different seals).
When you swapped in the Getrag from the 727 you didn't have any problems with the rear driveshaft? Could you get a measurement of yours?
I think i measured 59 1/2 or 60 inches can't remember which.
I'm going to get one made from a club cab rear driveshaft.
Postby ahale2772 » Fri Nov 04, 2011 4:08 am
nope, I was told I would need to switch it but i never did, it fit fine. I can try to get a measurement yes, need to pull it out anyways :x
