by ahale2772 » Fri Oct 28, 2011 5:30 am
3/4 should be 12x2.5, there is only the "rear wheel seal" kinda confuses it when you say inner or outer. I believe advance/napa/any other store are all mixed up on the sizes. IIRC the correct seal is a national P/N417158, best thing to do is to remove it and take it to the store, but more than once i've been told they dont have it
if your looking for the "axle seal" for the very outermost 8 bolts, you should wait and see if yours are the steel shim kind, if so, just clean them off, light coat of rtv and re-use them
