2wd d250 sway bar end links
Postby singlesmoker06 » Tue Jan 17, 2012 5:46 pm
As the title says, I have a 91.5 d250 that i grabbed a sway bar for off a 93 d350, got all the parts/bolts/ links and bushings for free all I had to do was pull it off. Ordered new bushings from napa , got those but I need the end links that mount to the strut bars... Anyone know where to get them ? Just seems like the easiest way to put I all together if not I'll just make some .... I can get real close to the answer I'm looking for using the search but still no results.... Thanks is in advance
91.5 d250 auto. $800 truck just for fun, 3200 spring, big injectors, big turbo, now have money out of pocket ....
SMOKED OUT DIESEL PERFORMANCE
817-578-5308
singlesmoker06
Re: 2wd d250 sway bar end links
Postby Horicon93 » Wed Feb 22, 2012 2:58 pm
Replaced all my swaybar bushings with Poly from Energy Suspensions just last Fall. So they're still available FYI.
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
