Looking for some dually parts...does anyone make them?
Postby Bschwarzli » Sat Jan 28, 2012 8:49 am
Was not sure if this is better in electrical or here...
Anyone know if these are still made or where I can get them? Chrysler is NS1. I know Chrysler was great for using standard parts (for example the lights are trucklite model 19s). Question is if the light was standard, was the rubber and harness as well?
Looking for the dually light rubber:
And harness:
Also looking for rear wiring harness that runs to the clearance lamps on tailgate/under tailgate. As the crew never had rear lights, its gonna get some. Issue is I cant find anyone making them!
Anyone have any thoughts? And why do I ask about the rubbers as it looks like I have some? I got 2 new ones with wiring years ago.....was not smart enough to get 4! :roll:
Thanks!
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Re: Looking for some dually parts...does anyone make them?
Postby Bschwarzli » Sat Jan 28, 2012 6:27 pm
Wiring harness solved. Trucklite apparently makes them. I will post my findings when they arrive.
As for the rest of the stuff though....
Bschwarzli
Postby Black93 » Mon Jan 30, 2012 7:03 am
http://www.mopartruckparts.com/tech/t013.html
He should have or can get just about anything you need. It's gonna be a little pricey though.
Black93
Postby Bschwarzli » Fri Feb 03, 2012 10:39 am
Black93 wrote:http://www.mopartruckparts.com/tech/t013.html
Thanks black! Will do some digging there.
Bschwarzli
Postby Bschwarzli » Fri Mar 09, 2012 11:12 am
Here is what I found:
Original Chrysler part number:
Yellow - 56003704
Red - 56003705
Replacement numbers from Trucklite (original manufacturer for Chrysler). Included with the "kit" is the black base and lense. The wiring harness is not included:
Yellow - 19016Y
Red - 19016 R
As for harness, there is a few options. I see the following two most useful:
Harness with 7" extra wire no connector (bare wire leads)- 94727
Harness with what I gather is the factory style connector (have not seen it in person but the illustration is correct) - 94821
Bschwarzli
Postby PToombs » Fri Mar 09, 2012 6:12 pm
Robert, post these numbers in the part numbers post, or sticky, or what ever it is.
Postby Bschwarzli » Mon Mar 12, 2012 5:26 pm
Will do!
Bschwarzli
