Help with parts selection
Postby 69HemiGTX » Mon Mar 05, 2012 6:52 pm
Howdy, y'all! I'm new here, but not to Dodges. I recently bought a 78 crew cab dually after I unexpectedly found it. Being a dually crew, it's 2WD. I'm going to swap it to 4WD using a donor truck, but I want to get the stance shown below. Are the parts used here stock or is there any lift? Any idea what spring and block combo is in the rear? This height is perfect for a dually (to me). It's not too high, and it just looks tough. The truck belongs to DieselHotRodder.
69HemiGTX
Re: Help with parts selection
Postby oldestof11 » Mon Mar 05, 2012 7:45 pm
Looks like a 255/85/R16 tires on maybe a leveled front springs. Basically 2" if the springs are really worn out.
Postby CumminsPower59 » Mon Mar 05, 2012 7:52 pm
Those look like 235/85's to me, 255's are quite tall. Looks like a stock height truck to me...well, from all the one's I have seen. stillsmokins' has the same "stance" and it's stock ;)
Postby JustinRhodes » Mon Mar 05, 2012 8:34 pm
I have nothing to add to this topic other than man that color is sexy...
JustinRhodes
Postby cmann250 » Tue Mar 06, 2012 5:37 am
JustinRhodes wrote:I have nothing to add to this topic other than man that color is sexy...
I said the exact thing :lol: I think that's B5 blue
Postby 69HemiGTX » Tue Mar 06, 2012 6:42 am
Do y'all know what size the 4X4 factory rear lift blocks are? If I'm not mistaken, 2WD duallies don't use blocks at all. I know mine sits awfully low. I'd love to look at mine just to know for sure what's going on under it, but it's 1200 miles away.
69HemiGTX
Postby CumminsPower59 » Tue Mar 06, 2012 6:46 am
I just measured the ones on my 92, they are six inches tall.
Postby RumbleFish » Tue Mar 06, 2012 7:13 am
That's not b5. Probably closer to b7. I think 92/93 had 6" blocks and earlier trucks have 4" blocks.
Postby 69HemiGTX » Tue Mar 06, 2012 9:07 am
Six inches?! :shock: Damn, those are tall. I think I'm going to mess around with different springs to help eliminate some of the block height. From what I've read, Chevy springs have a two inch deeper arch than Dodge springs, meaning a 2" Chevy spring is the same as a 4" Dodge. My plan is to use 56" Chevy springs in the rear to get a little softer ride while still being able to handle the load.
69HemiGTX
Postby CumminsPower59 » Tue Mar 06, 2012 9:11 am
You could also do a shackle flip so you don't have to use blocks...or maybe just add a one inch'er and the shackle flip kit to make the total lift in the rear six total inches ;)
http://ramchargercentral.com/jungleshdd ... p-hangers/
Postby 69HemiGTX » Tue Mar 06, 2012 9:16 am
As far as the color, judging by the PPG chip sheets I have, it looks like 1971 B5 (PPG PN 2306). 69-70 B5 (PPG PN 2019) is lighter.
69HemiGTX
Postby 69HemiGTX » Tue Mar 06, 2012 9:19 am
CumminsPower59 wrote:You could also do a shackle flip so you don't have to use blocks...or maybe just add a one inch'er and the shackle flip kit to make the total lift in the rear six total inches ;)
Oh yeah, I'm well aware of Jim's components. :D I spoke to him on the phone this past weekend. I'm going to use pretty much everything he makes, including his steering box braces and spring plates.
69HemiGTX
Postby CumminsPower59 » Tue Mar 06, 2012 9:22 am
Personally, I haven't used anything of his yet, but they look like they are made with quality and durability in mind. Eventually, I will upgrade my suspension with some of his parts, I like the greaseable part the best :mrgreen:
Postby 69HemiGTX » Tue Mar 06, 2012 10:25 am
OK, assuming the rear springs have the same arch between 2WD and 4WD, and I currently have no blocks, I should be able to use Jim's shackle flip mounts, Chevy springs, and no blocks to gain a total of 6" of lift, making my truck the same height as a stock 92-93 4WD one-ton. Clear as mud, right? :?
69HemiGTX
Postby CumminsPower59 » Tue Mar 06, 2012 11:04 am
Crystal clear. Depends on how much arch the Chevy springs have with the same amount of weight on them as the stockers to equal out the same height...
