AC Compressor
AC Compressor
Postby Hansen01 » Thu May 03, 2012 6:22 pm
Would anyone happen to know where to get a decently priced ac compressor, or a part number?
Under construction...
Hansen01
Re: AC Compressor
Postby ellis93 » Fri May 04, 2012 5:07 am
Not sure if they sell to the public,think they do,but 1-800-Radiator has good prices and a decent part. 1-800-723-4286.
Re: AC Compressor
Postby Hansen01 » Fri May 04, 2012 2:54 pm
Ok thanks :D Have a feeling its gonna be a toasty one this summer, and not one piece on my ac is good :roll:
Hansen01
Re: AC Compressor
Postby ellis93 » Fri May 04, 2012 3:54 pm
They sell kits. O-rings,dryer,expansion valve and compresser
Re: AC Compressor
Postby Mark Nixon » Sat May 05, 2012 8:37 am
Good luck finding ANYTHING, much less reasonably priced, for the A/C compressor on a Non-Intercooled truck.
To date, I've yet to find a new compressor clutch assembly for a non-intercooled A/C compressor.
You'd be better off to upgrade to the I/Ced compressor, if your's has any issues at all.
In order to do that, you need to swap out the lower coolant outlet/compressor mount.
It may require a different belt that's not listed as "factory", as well.
Re: AC Compressor
Postby Hansen01 » Sat May 05, 2012 3:52 pm
Mark Nixon wrote:You'd be better off to upgrade to the I/Ced compressor, if your's has any issues at all.
Mine doesnt even attempt to turn on, lol, not even when you hotwire it
Oreillys has one on there website for a 1990 it says, $259 :cry: complete ac rebuild not includeing getting my condensor fixed is like $335
Hansen01
Re: AC Compressor
Postby Mark Nixon » Sat May 05, 2012 4:09 pm
Actually, that you can even GET one, let alone the cost, is sort of a miracle.
Make sure it's a Lifetime warranty, you may need it.
Re: AC Compressor
Postby Hansen01 » Sat May 05, 2012 4:29 pm
http://www.oreillyauto.com/site/c/detai ... vi=1101238
says call for warrenty details :roll:
would you, or anyone else, happen to know the part number? i looked at mine and all i come up with is 09104 witch does not match the part number on the Oreillys one.
Hansen01
Re: AC Compressor
Postby Mark Nixon » Sat May 05, 2012 4:52 pm
If the picture is correct, which I believe it is, that is the right one.
The number you mentioned is probably a vendor casting code.
Either Cummins or Dodge uses a 7 digit number for their part OR casting numbers.
Some later Dodge stuff is also 8 digit.
Re: AC Compressor
Postby Hansen01 » Sat May 05, 2012 5:09 pm
well thank you Mark, i think i may just order my stuff from Oreillys then.
i also found this http://www.ebay.com/itm/57106-REMAN-A-C ... %26ps%3D54
But the way you describe these compressors it sounds like i need to go with the more exspensive one for longjevity, :lol:
Hansen01
Re: AC Compressor
Postby ellis93 » Sat May 05, 2012 6:14 pm
Not to be Donnie Downer here,but if the compresser from O'Reillys is painted black,it won't live long. I've used them,had customers bring them and its always the same thing. Leaks and noises :yuck:
Re: AC Compressor
Postby Hansen01 » Sat May 05, 2012 6:48 pm
:evil: hmmm,well if its black il tell em to keep it, lol
il have to call them and see what there warrenty is on them
Hansen01
Re: AC Compressor
Postby dazedandconfused » Sat May 05, 2012 6:55 pm
ellis93 wrote:Not sure if they sell to the public,think they do,but 1-800-Radiator has good prices and a decent part. 1-800-723-4286.
They are wholesale and won't sell to the public according to the guy i talked to yesterday.
Re: AC Compressor
Postby ellis93 » Sat May 05, 2012 7:17 pm
That sucks :sad:
Hansen01 wrote::evil: hmmm,well if its black il tell em to keep it, lol
1yr iirc w/ dryer and exp valve bought at the same time.
FWIW autozone has a better warranty and will be the same part. Give the OReilly part number to the Autozone Roid you talk to, they should be able to cross it in there system. It'll be a Murry part number,which both carry.
Re: AC Compressor
Postby Hansen01 » Sun May 06, 2012 4:06 pm
hmm, ok. Il have to give her a look, If there not very good from the start i would much rather have a good warrenty,lol
Hansen01
