96 chevy rims??
96 chevy rims??
Postby REBELHIGHBOY » Mon May 14, 2012 7:13 am
I was wondering if a set of 96 chevy 8 lug mag rims will fit my 92 w250?
REBELHIGHBOY
Re: 96 chevy rims??
Postby CumminsPower59 » Mon May 14, 2012 7:24 am
Not quite sure if any 3/4 ton and up chevys came stock with aluminum wheels, but if they are aftermarket, they should work. The stock steel wheels that 88 and up chevys came with have a slightly smaller center hole that doesn't want to fit over the stepped up section on the front hubs. The best way to know is measure your stock wheel center opening, and then measure the same opening on the wheels you wish to put on.
Re: 96 chevy rims??
Postby REBELHIGHBOY » Thu May 17, 2012 4:59 am
They ended up fitting they where not Chevy rims
REBELHIGHBOY
Re: 96 chevy rims??
Postby CumminsPower59 » Thu May 17, 2012 5:22 am
Good deal ;)
