power steering is messed up
Postby dodgeracerss » Tue Jan 09, 2007 6:03 pm
hey guys i repaced my power steering bracket broke so i replaced it now it seems to be moving around but i tighted everything not sure where to go from here and its licking too? help :cry:
dodgeracerss
Postby TWorline » Tue Jan 09, 2007 7:17 pm
When you had the power steering gear box off did you check the frame for cracks, inside and out? I take it you meant that it is leaking? If it is leaking where is it coming from?
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby dodgeracerss » Tue Jan 09, 2007 7:22 pm
no i didnt i had to hurry i have to work 7 days a week and i had 3 hours to get it done laying on the floor. its leaking from the bottom sorry for the spelling guys i type in a hurry lol
dodgeracerss
Postby TWorline » Tue Jan 09, 2007 7:35 pm
It could be leaking from the pitman arm seal, the bracket being broken may have contributed to this leak. As for ther still being slop in your steering have somebody turn the wheel with the motor off and see what is or is not moving when it should or should not be moving. :? :wink:
Tim Worline
TWorline
Postby dodgeracerss » Tue Jan 09, 2007 7:41 pm
ya it dose move i need to pull it back off and see if theres anything and i think its that arm so i should fix that too y im there
dodgeracerss
