While I'm sure this has been asked before, I was unable to find the info I was looking for, so If I missed it, go ahead and beat me
I'm looking at a '91 W350 parts truck, no drivetrain, only rolling chassis. It has, I assume the Dana 61 front axle, since it has the external lockout hubs. It was originally a non I/c 5spd truck.
What parts can I swap around between a later , say 92 D60 internal lockout axle? If I wanted to make the D61 a srw, can I use swap the spindle and hubs, or is it more involved? Knuckle and outer axle shaft as well? Unknown as to what the parts truck has for ratios, just like to be able to swap stuff around to better suit my needs, or desires. Going to lok at it sat and decide if I wanna buy it.
Thanks
P.S. I assume the rear axle is different and I cant make it a srw, I have to swap the entire axle assembly?
