exhaust idea
exhaust idea
Postby gomerpile » Thu Nov 15, 2007 4:02 pm
if i take off my exsisting muffler and add, say a three inch cherry bomb(great sound and when it clogs with soot i have "legal" straight pipe)and instead of going over the axle (biggest pinch in the whole system) just dumping it out straight out of the muffler with a chrome tip. would this cause any problems, (who knew i would use a idea off of an izuzu straight frame) but will this cause over heating in rear diff or brakes, and then when i romp on the new injectors it will look like a smoke screen of the similiar.
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby RumbleFish » Thu Nov 15, 2007 6:36 pm
My crew had leaky exhaust when I got it. It was real nice to crawl under the back of the truck to work on something and get covered in soot since everything under the rear of the truck was all sooty. I can imagine that this would do something similar. I say throw a 90 on it and dump it in front of the tire.
Postby wannadiesel » Fri Nov 16, 2007 6:46 am
No, it won't hurt anything. Everything from there back will be sooty after a while, but you won't overheat anything.
Best dyno: 408/844
wannadiesel
diesel guru
Postby gomerpile » Fri Nov 16, 2007 1:31 pm
how bad will the soot be with it dumping on the ground any how?
gomerpile
Postby oldestof11 » Fri Nov 16, 2007 6:46 pm
I do not think you will like it. I am driving a Suburban with a 350. Exhaust ends right past the driver-side rear door. It goes kitty, 2ft of pipe, muffler, nothing. On cold mornings (like today!:pukel:) all the exhaust billows out either side. Really smelly
Postby Begle1 » Sat Nov 17, 2007 2:12 pm
You're comparing cold gas smell with cold Diesel smell? Oh, for shame...
Postby cummins king » Sat Nov 17, 2007 5:54 pm
oh just say your whole rear end will turn black on you, but the inside of the tire will look really nice :lol: even with a 90D on itit will make it all black, i had that set up(not with the cherry) thats why i went to a single 7 inch stack
93 4X4 auto
cummins king
Postby gomerpile » Sun Nov 18, 2007 3:28 pm
well with this setup do you think i will free up some HP's or even more important some MPG's until i get the money to get a 4in exhaust, or do i really need a bhaf to help out, on the massive air in/out?
gomerpile
Postby cummins king » Sun Nov 18, 2007 7:00 pm
us put a flex pipe where the muffler is, but beware i got pulled over today for execive noise didn't get a ticket but....
93 4X4 auto
cummins king
Postby GO OVRIT » Tue Nov 20, 2007 10:03 pm
I don't know how it is where you are, but where I am , its not about whether you have a muffler, glasspack, straight pipe etc... its about the noise level. I'd just go with a piece of pipe in place of the muffler and keep tha tailpipe. It dropped the egts on my last 93 enough. When I ran it without the tailpipe, it only took a few days for my nice white and red shock to dissapear.
GO OVRIT
Postby gomerpile » Sun Nov 25, 2007 8:31 am
well i did it and its a lot louder, but i like the deep throaty rumble. where i dumped it under the bed it has a resonance to it, so now it shakes the back glass, but really its nice. should i see a drop in EGT's with this , because i saw another pound of boost :lol: and will this help gas milage, i really need every last MPG with diesel this price
gomerpile
Re: exhaust idea
Postby Ace » Fri Dec 14, 2007 1:48 am
gomerpile wrote: ...just dumping it out straight out of the muffler with a chrome tip. would this cause any problems...
That's kinda what I did, except for a section of 4" Cat dozer stack that puts it out in front of the rear wheel. It's a bit louder in the cab with the small Magnaflow 4" mufffler, but not objectionable. It's Waaaaay louder outside. Keeping the tip out well past the body seems to dampen much of the sound from being transmitted back inside the cab. A rather short, custom 4" exhaust with only one real 35deg. bend in it aft of the DP:
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_75.jpg
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_80.jpg
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_78.jpg
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_76.jpg
Ace
