by CumminsPower59 » Mon Nov 18, 2013 11:55 am
When I swapped steering gears on mine, I bled the system by having it jacked up, and the engine off, then slowly turned the wheels side to side. Then I would fire the truck up and rev it to about 1500rpms, when you look inside the reservoir, you'll see the fluid level drop immediately when the engine is revved up. I repeated the whole cycle a few times and haven't had an issue since.
Hope this helps you
