nooblet wrote:Thanks for the info as always guys! Looks like I'm going to leave it rigged up like that until I need to use the AC again. Once it warms up I'll troubleshoot the vacuum problem and get it all working properly.
Chris
PToombs wrote:On the compressor, get a belt for a non-A/C truck, and bypass the compressor. The only difference is the belt routing, and the length of the belt. Then in the spring, take care of the compressor.
The plus side to this, you have a spare belt in case the compressor craps out, or you lose the regular one on the road.
flashgordon wrote:Yes.
Start with the Vac pump under inj pump bolted on the drivers side of the block. Check vac there, and work your way up following you lines.
Flash
TWorline wrote:Throwing the belt will not affect your power steering, it is gear driven.
flashgordon wrote:I know the way the A/C line rought is a little fifferent.........but i thought the compressors were the same........Mybe not.......
I was re reading your post and you say that the belt squeals all the time and noise get lower with the a/c on right?
If the bearing in the a/c clutch is going bad then the noise would go a way with it engaged.
If the compressor was ready to shell out, then the noise would go a way when you turned the a/c off............
I think you have a bad tensioner or fan hub bearing.
Putiing the non a/c belt on would tell you if the a/c is at fault.
