Better Ride
Better Ride
Postby CWT » Fri Apr 11, 2014 2:53 pm
My truck is a single wheel D350. It done have a overload spring on it. But the previous owner said it rode like crap. I don't have one to look at, but is the rear springs in a D250 the same or is the spring in my truck the same as a dual wheel truck? Or are they all the same?
CWT
Re: Better Ride
Postby comotionman » Sat Apr 12, 2014 1:51 am
They are all more or less the same. The number of leafs can change. The overload leafs you mention are a separate leaf pack rides above the main pack and engage strikers mounted on the frame when the load weight becomes enough to allow.
coupla trucks non & ic, 2nd gens, various other
comotionman
Re: Better Ride
Postby PToombs » Sat Apr 12, 2014 5:23 pm
I have a 92 D350, I only have a regular 5 leaf pack and 1 heavy one below it for a helper. I think the duallies and the heavier sprung trucks had the 2nd overload pack.
Re: Better Ride
Postby meby » Sun Apr 13, 2014 6:55 am
PToombs wrote:I have a 92 D350, I only have a regular 5 leaf pack and 1 heavy one below it for a helper. I think the duallies and the heavier sprung trucks had the 2nd overload pack.
dad's heavy 3/4 ton has 5 leaves on the primary and another 4 on the overloads. It rides pretty rough.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Better Ride
Postby CWT » Mon Apr 14, 2014 1:00 pm
I may try shorting the spring pack up some then. I don't plan on hauling a D12 dozer with it.
CWT
Re: Better Ride
Postby dazedandconfused » Mon Apr 14, 2014 3:50 pm
My D150 only has 3 springs in the pack.
Re: Better Ride
Postby CWT » Tue Apr 15, 2014 7:58 am
I got a friend that took some leafs out and it was still pretty ruff. Hell its a work truck what can you expect? Ha.
CWT
Re: Better Ride
Postby bmoeller » Sun Jun 08, 2014 5:24 am
No extra overloads one mine Pete. Same leaf pack my W250 had.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Better Ride
Postby Sutter1stgen » Sun Jun 08, 2014 5:34 pm
Take every other leaf out of the pack instead of the bottom two(if you have 5). That will help some.
I have chevy 52" rear springs up front and the same configuration I just mentioned in the rear for now. Truck hits bumps a bit more cushioned than my 14' with the coils in the rear. Only it doesn't recuperate and track well compared to my new truck. On a long road trip it would be a toss up in the ride department. But my 91' would keep you awake with its real truck feel. Lol
Eric
Sutter1stgen
