Bilstein 5100 shocks
Postby hemislave » Wed Apr 30, 2014 6:45 pm
HI evryone, can anyone tell me the exact part#s for the 5100 bilsteins? I ordered the parabolic springs from Carrier Spring Service, and I"m probably gonna need longer schocks. Thanks in advance! :) I should specify these are the front shocks... :roll:
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
hemislave
Re: Bilstein 5100 shocks
Postby CumminsPower59 » Wed Apr 30, 2014 9:58 pm
I got on a website that had all the specifics for the 5100's and found some that were about 2-4" longer than stock. Just had to dig through all of them and compared them to the stock height units.
Postby hemislave » Thu May 01, 2014 3:55 am
OK ,I did a search on here and did'nt come up with anything. Amazons web site is'nt very specific either.
hemislave
Postby BILTIT » Thu May 01, 2014 9:46 am
33-185590
collapsed=13.66''
extended=21.63''
33-185569
=17.91''
=29.71''
33-185552
=15.91
=25.93
33-185542
=15.12
=24.31
Derek B.
BILTIT
Postby hemislave » Thu May 01, 2014 7:27 pm
Thanks for the info Biltit !!!
hemislave
Postby BILTIT » Thu May 01, 2014 8:34 pm
No problem. With my 2" lift i run the -542's up front and the -569's in the rear but i would measure to be sure.
Derek B.
BILTIT
Postby RCCUMMINS89 » Wed May 14, 2014 11:54 am
Biltit- did you have to change bushings or anything? Or were they a direct bolt on?
Postby BILTIT » Wed May 14, 2014 3:28 pm
Direct bolt-on.....sorta. The rubbers are a 1/16" on the small side (ID) if i recall, i greased them and used a hammer to get them to pop over the stud.
Derek B.
BILTIT
Postby RCCUMMINS89 » Wed May 14, 2014 3:45 pm
Ok, cuz I've got some on order.....
For the front:
33-185552
=15.91
=25.93
For the rear:
33-185569
=17.91''
=29.71''
Hopefully I got the right ones.
Postby PToombs » Wed May 14, 2014 4:51 pm
I put shocks on something and drove the bushing out so the rubber was right on the stud. Never had a problem with it.
Postby BILTIT » Thu May 15, 2014 8:29 am
Yes i removed the bushing aswell, the rubber is still a tight fit.
Derek B.
BILTIT
Postby RCCUMMINS89 » Mon May 19, 2014 9:10 pm
Put mine on tonight... I just drilled the rubber out a little bit.
I'm honestly not that impressed. My heavy ass truck apparently needs more... You know how you rock the vehicle and are supposed to have like 1.5 rolls? With my old completely worn out pos Skyjacker shocks, I had 8 rolls :shock: .
With the Bilstein shocks, I still have about 4 rolls back and forth :roll: .
The ride is better on the street, but its actually worse on dirt roads with pot holes.
